Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: I'm going NUTS! ewfntldr
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Hi all,
    Trying to get horm working, downloaded the latest XPe ewf stuff from here but i cannnot get the system to boot using the replacement ntldr. It's driving me insane. read-only, hidden, rename in something else, rename it back, stab it, ARRRRRG. It just sits after the bios and doesn't load the os.
    Thanks for any help,
    Sam
    Dec 2006
    Ahh well, must have been a corrupted file.
    Downloading the latest ewfntldr from a different source fixed the problem.
    Even though a hex editor decided the two versions were bit-by-bit identical, one worked and one didn't. Great, that's hours of my life i want back ;-)
    May 2004
    Michigan
    Am I just stupid, or what? I can't find ntldr on my hard drive
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    Quote Originally Posted by rdc_3200 View Post
    if you have a second hard drive, its probably somewhere on there, and not on the HDD your OS is installed on. some BIOS are ****in retarded and need to fix that. especially if you are using one SATA HDD and an IDE HDD. i thought mobo manufacturers fixed this problem...
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    May 2004
    Michigan
    I've only got one hard drive, but it's partitioned...I've searched the whole thing, but can't find it...
    Apr 2007
    Florida
    check your C:WINDOWS\SYSTEM32 directory...it should be there...
    Subwoofer: removed
    May 2004
    Michigan
    I did check the c:\windows\system32 directory, but am not seeing ntldr...everything seems to be functioning, but the file just isn't there!
    I'm trying to set up the whole EWF/HORM thing, and I've got to replace the existing ntldr with a renamed ewfntldr...should I just copy the file over to system32 and rename it? do you think that will work?
    May 2004
    Michigan
    the only thing I can think of is that I'm using XP pro when everyone else is using XP, but I don't see how that would make a difference
    Apr 2007
    Florida
    here...try this...go to your system32 directory and at the top of the screen, you will see "Tools" on the toolbar. click on that and select "Folder Options"...then when that opens up click on the "View" tab...from there, you need to check the bubble that says "view hidden files and folders"...
    now you should be able to see it...
    and XP and XP PRO are the same thing....people dont normally use XP home because it has some major problems...M$ crippled that OS...not to mention, XP Pro can be downloaded in about 20 minutes using bittorrent...and keys can be found everywhere...
    ntldr is the set of instructions windows uses to bootup...at least part of it...hence "NT LOADER"
    Subwoofer: removed
    May 2004
    Michigan
    I've already got that option checked...but still can't see the file...
    I copied ewfntldr into system32 and renamed it to ntldr and windows didn't seem to mind (no error or anything saying there was already a file with that name)
    I've run out of ideas
  1. touchscreen problem drives me nuts ! plz help
    By diskey in forum Input Devices
    Last Post: 04-24-2006, 09:15 AM
  2. Coming out of hibernation - Mouse sometimes goes NUTS!
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 01-27-2006, 07:38 AM
  3. This guy has gone NUTS!!!!!
    By kingtut in forum General Hardware Discussion
    Last Post: 12-22-2004, 10:50 AM
  4. EL driving me nuts!!
    By Jarrod in forum LCD/Display
    Last Post: 02-24-2002, 02:04 AM
  5. guys at MECI don't reply...I'm getting nuts
    By maromba in forum General Hardware Discussion
    Last Post: 01-21-2000, 09:27 AM
