Results 1 to 7 of 7
Thread: EWF boot problem
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    EWF boot problem
    I recently got EWF working on my hard drive in preparation for creation of a CF boot disk. The problem is that after I enable EWF the "Windows did not boot correctly last time" menu shows on every boot, and so unless I hit enter (which is rare because my keyboard is usually put away), I have to wait 30 seconds for it to time out. Very annoying. Note that this does NOT happen the first time I boot Windows after I turn on EWF, only on subsequent boots. Any clue as to why this happens or how to fix it?
    In case it's relevant, I'm using minlogon, and have an M2 which has been spotty about turning the computer off when the IGN switch is turned off (but I have it set to kill the power at 1 minute), and I have the computer set to "shutdown" (no hibernation, as my CF won't be able to support it).
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Rename bootstat.dat something else, in your windows directory.
    Problem solved.
    Nov 2006
    Everett, WA
    Thanks! I'll try that. While I'm happy with it "just working", could you explain what it does?
    FLAC SFiorito's Avatar
    May 2004
    bootstat.dat is updated on each successful boot by NTLDR. If it's not there then the Automatic Recovery does not show up anymore.
    Nov 2006
    Everett, WA
    Okay I searched for the file and it doesn't show up. Yes, I have hidden files viewable. The only file in c:\ with the word "boot" in the filename is boot.ini.
    I loaded it as normal, turned off EWF, and then searched. I can't delete files with EWF turned on, right?
    Dec 2006
    c:\windows matey
    Nov 2006
    Everett, WA
    Ah, search doesn't look in c:\windows. Done and done. Awaiting spectacular results on next few boots. ;-)
  1. Replies: 14
    Last Post: 09-11-2008, 03:14 PM
  2. igps-500 boot problem
    By dettlej in forum GPS
    Last Post: 05-01-2007, 07:17 PM
  3. M10000 boot loop problem
    By zx16v in forum General Hardware Discussion
    Last Post: 04-19-2007, 09:03 AM
  4. M1000 boot problem, no video, no POST
    By fritz_fx in forum General MP3Car Discussion
    Last Post: 02-01-2006, 10:14 AM
  5. EWF problem
    By Ascension in forum WinNT Based
    Last Post: 06-28-2005, 11:50 AM
