Results 1 to 5 of 5
Thread: winlogon keeps duplicating itself
    Constant Bitrate cubanmoses's Avatar
    May 2003
    miami/orlando
    hey guys
    I'm using xp and i can't copy minlogon over winlogon because winlogon replicates itself every time i try. I changed the first winlogon.exe to winlogon.exe.bak. then i tried to bring in minlogon and change its named to winlogon and it would give me an error that a file with that name already exists. so then i tried changing the name of the file (minlogon) before i brought it in the system32 folder to copy over winlogon and it'd let me do it. a few seconds later minlogon would become the old winlogon. any suggestions on how to overcome this would be great.
    project: built, updating software
    comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
    software: nlited xp, roadrunner
    screen: TM-701L touchscreen
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    future: gps with and navigation software
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Tried safe mode?
    May 2004
    Michigan
    I had the exact same problem. I eventually got past it by disabling windows file protection. I did so by following a combination of steps from the following links.
    http://www.governmentsecurity.org/archive/t3990.html
    http://www.jsifaq.com/SF/Tips/Tip.aspx?id=2546
    http://www.jsifaq.com/SF/Tips/Tip.aspx?id=8575
    After I had WFP disabled, I was able to rename winogon.exe and copy over a renamed minlogon. Hope this helps.
    May 2005
    You can also go and delete winlogon.exe from the dllcache folder
    Jan 2010
    so simple
    Yeah !
    Winlogon.exe kept resurrecting because it was in dllcache.
    I've just spent hours trying to do this because Debug wouldn't work in my nLite version of XP Pro. I didn't have autoexec.nt, config.nt and about 10 other files and I couldn't disable WFP.
    An old thread resurrected but it worked for me.
  1. XP Winlogon
    By AlienEclipse in forum Software & Software Development
    Last Post: 09-02-2008, 01:56 AM
  2. How to: Duplicating a radio bezel.
    By Giuliano in forum Fabrication
    Last Post: 02-21-2006, 11:14 PM
  3. Duplicating The Monitor rather then Extended Desktop
    By butwhyowhy in forum LCD/Display
    Last Post: 05-19-2005, 05:39 PM
