Results 1 to 4 of 4
Thread: Swap file issues
    May 2005
    Swap file issues
    Howdy folks,
    I received my Seagate CompactFlash photo hard drive the other day and installed Windows XP onto it. The drive is a 4GB microdrive in a type 2 CF package. Fits perfectly with my SBC that boots from the CF slot. No worrying about EWF stuff either as it's a regular, albeit a bit slow, hard drive.
    My issue is this. On startup at the welcome screen, Windows prompts me that there was an issue with the paging file and a temporary one has been created. I know that there is plenty of room on the drive, so what gives?
    I know that Windows cannot use a removable drive for the swap file, and I'm pretty sure it is a fixed disk, since FDISK saw and partitioned it.
    Any suggestions will be helpful!
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by sebberry View Post
    Howdy folks,
    You can disable the swap file altogether, i always thought that compact flash cards only had a limited no of writes unlike a HD, and without EWF it would cause problems like what your experiencing now?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    May 2005
    ^Yes, they do have a limited number of writes, which is why mine is a microdrive in a CF type 2 package, not flash memory...
    I disabled the swap file and that solved the problem. Somehow Windows now manages to still create a swapfile which is fine...
    Nov 2006
    Wales, UK
    sweet im experimenting with CF, im using a CF to 2.5 hard drive converter on my laptop to see if its stable enough.
    CarPuter Progress:
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 01:39 PM
  2. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 07:48 PM
  3. Need help with a batch file
    By djXternal in forum General MP3Car Discussion
    Last Post: 11-22-2005, 01:26 AM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. File Info / Movie Info
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:42 PM
