And smaller, and more shock resistant. And lower seek times, so faster where you have bad access patterns across the disk (but slower in raw streaming throughput). And they eventually die if you write too much to them.
If you want a fast boot, look at hibernate or suspend, also consider HORM. Strip down your system as much as possible, turn off stuff you don't use (network is a good one to go).
I unzip windows from a flash disc into a ramdisk and boot from there. That is quite fast (17 seconds cold boot including POST, Win98SE).
LinkBack URL
About LinkBacks
