Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Windows XP Pro - Embedded or No?
  1. #11
    FLAC SFiorito's Avatar
    May 2004
    if you use XP Embedded you can keep or remove whatever you want, so yes you could include the .NET Framework. it's just a matter of understanding what OS features you need and building the right image.
  2. #12
    Low Bitrate wmpwi's Avatar
    Sep 2007
    Western Michigan
    Quote Originally Posted by jonessc View Post
    Might be worth listing as well what services you can 'safeley' disable from bootup, ive been experimenting with nlite, using a TinyXP lastsession.ini, I know theres already alot of material on the web, but its hard to know which ones are essential for safe running on a car pc, i def disable these
    - Printspooler
    - Indexing service
    - Fast user switching
    +1
    A computer lets you make more mistakes faster than any invention in human history
    - with the possible exceptions of handguns and tequila.
  3. #13
    May 2005
    I recently received some tools for embedded development (http://www.sjjmicro.com/XPES_Tools_R2.html) so hopefully I will have a working embedded installation soon
  4. #14
    Feb 2006
    Melbourne, Australia
    With the embedded systems, does it still opperate like a normal windows version?
    It is exactly like normal, standard WinXP, you just componentize it to suit your application - one caveat though, there is a special method of "patching" or applying hotfixes, but this wouldn't be that essential in a carputer if not connected to the internet all the time.
    If it is, then there is a fair bit of work involved in rolling out this runtime patches.
    But, it is fun to play with, very, very flexible, and allows you to componentize each and every driver for your system, same with applications - it's a lot of work, and trial and error, capturing registry changes, importing them and creating components - but, once this is done for your system, roll-outs are so simple, quick, and clean!! To top it off, once the First Boot Agent (FBA) has done it's thing after startup, everything just works - all the drivers are there, no need for post-installation actions.....I told you it was nice...
    I am at this point with my design, all drivers componentized, embedded, WiFi, Realtek sound, VGA, Chipset, but, the Realtek sound gave me the crap when componentizing, working now though.
    Next on the agenda is the time-consuming application components-design/testing, ie Centrafuse, OBD-II interfaces, etc...
    Enjoy, it's fun.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  5. #15
    Dec 2007
    My problem with xp embedded has been deployment.
    I've been unable to figure out a way to deploy the resulting image onto my laptop without having to use an annoying RIS server etc. I personally would like to just burn a cd and do a standard install
    Anyone have insight to offer into this?
  6. #16
    May 2004
    all you need to do is format the disk and copy the XPe image onto the laptop drive. you could boot with a WinPE/BartPE disc and have the files on a network share or a thumbdrive for instance.
  7. #17
    Dec 2007
    tried
    Ya, I tried just copying the image to the formated drive, didn't do any good.
    Tried formating it with a normal format, tried formating it as bootable, etc. etc.
    just says there is nothing to boot to.
    Honestly I'm getting tired of setting up this carputer so I may just stick with XP I just finished coding a plugin for RR and I'm not sure I want to dig into creating an entire XP image, heh.
    The only reason I wanted to use embedded was so that I could boot from a single hibernation image. Do you know if it is possible to do this with just straight up XP pro?
  8. #18
    May 2005
    The example here says it is for a virtual machine, but the format and copy process is the same:
    http://msdn2.microsoft.com/en-us/lib...inetovirtualpc
  9. #19
    May 2004
    you wanted to use HORM? yes, that's possible using the right components from XPe with XP. Search the forums or go to my instructions here: http://granturing.blogspot.com.
  10. #20
    Dec 2007
    Awesome, thank you so much.
  1. Windows R XP and Windows Xp ????
    By choier1983 in forum Software & Software Development
    Last Post: 04-14-2007, 03:50 AM
  2. StreetDeck and Windows XP Embedded
    By N6BER in forum StreetDeck
    Last Post: 04-13-2007, 05:38 PM
  3. Running FrodoPlayer on Windows XP Embedded?
    By Lupo in forum FrodoPlayer
    Last Post: 07-23-2004, 08:50 AM
  4. Windows XP Pro
    By chut in forum Classified Archive
    Last Post: 01-02-2004, 11:29 PM
  5. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
