Results 1 to 6 of 6
Thread: Can't disable EWF with CF
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Okay so I finally got my ExtremeIII CF to boot Windows. YAY (although it's no 10 second boot, sigh slow BIOS). I turned on EWF to protect the volume. Now I want to make a couple changes, so I hit "ewfmgr c: disableandcommit -live" and it hangs. Any solutions for this?
    FLAC SFiorito's Avatar
    May 2004
    The command is: ewfmgr c: -commitanddisable -live
    Not sure why it's hanging though....
    Nov 2006
    Everett, WA
    Yeah that's it, I have the enable and disable in bat files on my desktop, so I don't really remember what the syntax is.
    Does ewf care if it's set to a fixed drive or whatever?
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    If you have made a lot of changes to the protected volume the command does not hang, it takes a few minutes to complete. Be patient, or turn off EWF before making changes, make your changes, then re-enable it. I once sent that command after updated a ton of stuff and it sat there for 3 minutes before it wrote all the changes from ram to flash.
    Nov 2006
    Everett, WA
    Can I turn it off, make changes, and then re-enable, then reboot and have everything changed? I'll give this a try, thanks! I've been using EWF on my hard drive for the past few months and haven't ever had it take longer than a blink of an eye.
    Nov 2006
    Everett, WA
    I've let it sit for 20 minutes, no dice. Looks like I'll have to redeploy.
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 01:39 PM
  2. Super small XP install
    By knubile in forum WinNT Based
    Last Post: 04-26-2008, 02:44 PM
  3. nLite and USB Devices
    By Nobias in forum WinNT Based
    Last Post: 01-20-2005, 10:11 PM
  4. nLite making me nSane: Frodoplayer issue
    Last Post: 01-13-2005, 12:09 AM
  5. XP Pro on CF card working!!
    Last Post: 01-03-2005, 06:48 PM
