Results 1 to 9 of 9
Thread: Possible to Access Network Resource Using Minlogon
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Is there anyway to access local network drives after moving over to minlogon instead of winlogon?
    I'm not sure if the boot time decrease is worth the no network access.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Jun 2007
    St. Louis
    I briefly looked for a way, but as I don't have a whole lot of time to dedicate to the search I just went back to winlogon. minlogon didn't really shorten my boot times a lot anyway.
    Elsewhere
    If a drive is networked, then it's not local. If it's local, then it's not networked.
    Considering that access to network resources is tied to login, you're going to need to either make your network resources available to anyone that accesses them or you're going to have to ditch minlogon.
    How about the Wiki?
    Oct 2003
    Poland, OH
    I am willing to allow anyone to access my network shares because they are all inside my local home network. That is how I thought I had it setup anyways.
    I go into my share permissions and it has EVERYONE - Full Control. Same for the security tab. What am I doing wrong?
    Oct 2003
    Poland, OH
    Hey Pervert.. Are you able to help me out? I'm about to put my CarPC in my truck but want to be done tweaking the OS before I do it.
    If I can't access network drives with minlogon I will go back to winlogon. I don't want to go back if it's possible though. Like I said.. My network shares are everyone full control.
    Thanks for the help.
    Jun 2007
    St. Louis
    fyi - mine were the same way. Everyone with full access on both share and ntfs permissions. No domain, just workgroup. Every other machine can access the share without a username/password unless I switch to minlogon.
    Oct 2003
    Poland, OH
    Your's WERE the same way? When you say "were" (plural) I assume you're talking about your network shares?
    I guess I'm confused by your post.. Are you saying you have this problem or not? Did you fix it only by going back to winlogon?
    Thanks much.
    Jun 2007
    St. Louis
    sorry for the confusion... let me try to explain it better (been a long day...took the kids and mother 'n law to the zoo... should have left some of them there too)
    Yes, I've always set my network share here to Everyone Full on both share and ntfs permissions. I used the word "were" in the tense when I was running minlogon. After switching back to winlogon, I was able to access the shares without issue. With the only thing changing was going from minlogon -> winlogon.
    So basically... on the same machine - and I've done this with 2 so far in my house. If I'm using winlogon I can access the network share just fine with no prompts for credentials. If I'm using minlogon I can't access them.
    I've even gone as far as to re-install XP from scratch and try. It's done this to me on both an N-Lited version of XP Pro as well as a full install of XP Pro.
    Feb 2008
    minlogon is faster to boot but impossible to work with network drives
    So I go back to WINLOGON unless we find the solution to connect NETWORK resources ....... very bad. We all were so happy have fast boots ..... and now back WELCOME SCREENS jaja
  1. Replies: 268
    Last Post: 05-28-2012, 09:49 AM
  2. Need help with Network DVD rom access
    By inniss777 in forum General Hardware Discussion
    Last Post: 07-19-2006, 06:58 AM
  3. Easiest way to connect to random wifi network?
    By bosskong in forum Wireless Communications
    Last Post: 03-23-2005, 11:41 AM
  4. Power line homeplug wifi 802.11b access point network
    By Jammer in forum Wireless Communications
    Last Post: 01-16-2005, 04:23 PM
  5. Wi-Max : A viable alternative to Wi-Fi?
    By Maxis24 in forum Wireless Communications
    Last Post: 03-26-2004, 05:35 PM
