Results 1 to 8 of 8
Thread: resume from hibernbation, bypass user click here?
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    i set my truckputer to go into hibernation via the p1900. it goes into hibernation fine. but it always brings up the hibernation resume log into windows screen (x programms running, click to resume). how do i bypass this? i though it would be something in the user account control panel, but nada. i searched all through the FAQ and did a search to no avail. please help! if this is in the wrong section, then im sure an administrator will move it for me.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    You actually can't change this logo without hacking the ntldr which is a little bit scary and done incorrectly will hose your system. It has been discussed http://www.mp3car.com/vbulletin/winn...bernation.html
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2006
    Colorado, but Canadian!
    As long as there is only 1 user it should automatically do it, or is this not what you are talking about? You dont want that blue screen with the windows logo and the user name you click to log in correct?
    Usually what happens in XP, is when you install SP2 or .NET, there are 2 or 3 more users created that are invisible. You can disable them from logging in, and if you do, you should get the default straight to the desktop...
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    Oh wow! I was talking about a completely different thing... Never mind my post :P
    Elsewhere
    In addition to what 2k1Toaster said...
    Go to Control Panel > Power Options > Advanced tab
    Uncheck "Prompt for password when computer resumes from standby" and click OK.
    Also...
    Start > Run > control userpasswords2 > OK
    Make certain that "Users must enter a username & password" is checked.
    Highlight the user you want to automatically log on.
    Unheck the box for "Users must enter a username & password"
    Click APPLY
    Enter in the password for the user that was highlighted (if any) and click OK.
    Now that particular user will automagically log on and you should not have any log on screens when resuming from hibernation.
    How about the Wiki?
    Apr 2007
    Edmond, Ok
    Quote Originally Posted by NiSlo View Post
    no where near what i am wanting to do. i dont want it to load up at all upon resuming from hibernation.
    Quote Originally Posted by 2k1Toaster View Post
    yes, i want it to go back to windows and not a logon screen when it resumes from hibernation. i did a fresh install of xp home edition sp2 when i installed the truckputer. when i made my account info like every install of xp ive had asks for, it has my (the admin) and in user accounts it has guest (disabled).
    Quote Originally Posted by DarquePervert View Post
    Also...
    Click APPLY
    this info sounds like it will help me out exacctly as needed. thanks a bunch! if more problems arise, ill be back.......
    i spent like 8 or so hours in my truck messing with setting on my truckputer. and trying to get activesync for xp to work with bluetooth, then pdanet to work with bluetooth. im in okc, ok, so my power has been out since sat evening. all i could do is sign in online via bluetooth or the my sync cable. didnt wanna deal with a dangling cable when im driving, soooo bluetooth was the was to go.
    Apr 2007
    Edmond, Ok
    im bout to hookup my o2 sim when its not raining ice here/ and finish my audio install.
    Apr 2007
    Edmond, Ok
    oops, that was supposed to go to the s10forum....... im using my truckputer if ya cant tell :P
  1. Replies: 22
    Last Post: 08-06-2006, 04:57 PM
  2. Cingular PDANet via bluetooth
    By DarquePervert in forum Wireless Communications
    Last Post: 06-23-2006, 05:22 PM
  3. We Need Ratings.
    By Fusion-One in forum Mp3car Forum Suggestions/Comments
    Last Post: 06-11-2006, 09:16 PM
  4. Window XP , bypass user account select screen
    By lookinco in forum Newbie
    Last Post: 09-05-2004, 04:31 PM
