Results 1 to 4 of 4
Thread: Cannot resume when using CF to IDE adapter.
    Jan 2008
    I have a problem i've been unable to get around and i'm wondering if anyone has some experience they could share to assist me.
    I set up an nLited install of windows XP following the instructions given by SFiorito in this post
    everything works well (great instructions) until i transfer the install to my CF card and try to boot. I created a hibernation file before copying the image over and then when i boot off the flash card the machine begins to resume and as soon as the progress bar gets to the end it blue screens. I tried using F8 to do a normal boot and got into windows ok, set up my system again and then tried to create a new hibernation point, the process of hibernating took a really loooong time and the when i rebooted it was as if there was no hibernation and just went straight to new boot.
    My system is
    nLited XP Pro
    VIA EPIA NX12000EG
    1 gig RAM
    4 gig partition on WD1200 HDD (for setting up and testing)
    4 gig Sandisk UltraII (for deployment)
    So just to re-iterate the system works as expected when using the regular HDD and only has a problem with the CF card, the CF to IDE adapter is this one
    This site claims this adapter supports UDMA but i have to disable UDMA in the bios when using it or i get corrupt data.
    Any comments or advice would be appreciated.
    Thanks for helping
    FLAC SFiorito's Avatar
    May 2004
    Does the CF card appear as a fixed or removable drive? Hibernation does not work on removable drives. If it blue screens maybe the hibernation file is corrupted on the disk. Is it a "real" SanDisk drive? A while ago people were getting screwed by cheap chinese knock-offs from eBay. You can alwas try another CF-IDE adapter.
    Jan 2008
    Hi SFiorito,
    Thanks for your reply and also for your guide to using EWF with XP.
    I tried a new adapter ( and fortunately i can now create a hibernation file and resume without a problem.
    Interestingly when i tried setting a resume point with the adapter plugged into SATA plug #2 (Slave) then swapped it, and tried to resume with it in plug #1 (master) i got the same BSOD as before.
    I suspect the CF to IDE adapter i pointed to in my first post may be a little sketchy, i dont think using it with a card that doesn't support was helping but overall i wouldnt recommend it for this application.
    May 2004
    Glad things are working now....Unfortunately there are a lot of shoddy adapters and CF cards out there. That's why I sound like a broken record always pointing people to those 3 or 4 adapters and the well known CF manufacturers versus the cheap eBay stuff.
  1. San Disk & IDE adapter
    By Cross_ in forum General Hardware Discussion
    Last Post: 04-26-2007, 12:55 AM
  2. Bytecc BT-200 USB 2.0 to IDE Adapter power?
    By hauler34 in forum Input Devices
    Last Post: 11-07-2006, 01:02 PM
  3. Replies: 1
    Last Post: 11-05-2006, 09:43 PM
  4. Replies: 2
    Last Post: 06-08-2005, 01:39 PM
  5. Replies: 5
    Last Post: 12-24-2003, 01:02 PM
