Results 1 to 5 of 5
Thread: HORM without EWF
    Dec 2007
    HORM without EWF
    I found the following solution to enable HORM without EWF:
    I used the files extracted from "XPeSP2FeaturePack2007.iso" downloaded by MS site.
    1. replace the original ntldr with renamed ewfntldr using recovery console on xp CD and restart
    2. copy ewfapi.dll, ewfdll.dll, ewfmgr.exe in system32 dir
    3. copy ewf.sys in system32\drivers dir
    4. copy horm.dat in root dir (same as ntldr), c:\
    5. add to the registry the ewf informations using a .reg file (ones indicated by sfiorito here: http://mason.gmu.edu/~sfiorito/eXPinstall.htm)
    6. enable hibernation support on the system if not yet
    7. restart and use command prompt as following:
    Microsoft Windows XP [Versione 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Administrator>ewfmgr
    RAM (REG) Configuration
    Device Name "\Device\HarddiskVolume1" [C:]
    HORM Active
    If you see "HORM active" now you can try to hibernate and resume as many times you want by the same hiberfile.sys
    EWF protection is still disabled till you don't enable it using ewfmgr.exe
    I did everything exactly as it is described above but when I hibernate my PC it resumes only once. Then if I shut it down again it will start normally, but it should resume from the hibernation file. Could anyone help me ?
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    That seems a bit long winded it you just want HORM
    my understanding is just put resmany.dat onto root of c:
    then simply hibernate
    then it will use that same image everytime until you delete it, or press f8 during boot and select delete restore data.
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Dec 2007
    I also tried to put resmany.dat in the root of my hard disk, but it doesn't help either.
    As far as I know horm.dat replaced resmany.dat in the latest edition of XPe.
    Has anyone managed to enable HORM without EWF and could verify steps described in the first post of this thread ?
    Nov 2007
    * bump *
    i'm wanting the answer to this also
    1997 Chevy Tahoe
    Planning 30%
    Installation 15%
    Overall Progress 12%
    worklog
    FLAC SFiorito's Avatar
    May 2004
    it's horm.dat with the newer files from XPe FP 2007. you must have EWF enabled for HORM to work.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  1. Replies: 12
    Last Post: 03-16-2009, 08:00 PM
  2. RR and EWF with HORM
    By carlospelos in forum Road Runner
    Last Post: 04-08-2007, 04:26 PM
  3. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
  4. horm without ewf
    By z.1 in forum WinNT Based
    Last Post: 06-18-2005, 11:38 AM
  5. using EWF + HORM
    By BOND007BE in forum WinNT Based
    Last Post: 03-29-2005, 03:41 AM
