All are realistic
1. To make a small image of windows xp you can go about it 2 ways:
- Get a program called Nlite link:www.nliteos.com, as long as you have an original XP disk, you can go through a wizard and essentially remove all the 'bloat' that isnt needed out of Windows. If you look through this section of the forum, there are people that uploaded a file called 'lastsession.ini' it contains a pre-configured setup, that someelse has used
- Search for 'TinyXP' most versions are illegal, however there was one, that would make it from your licence key and original XP disk some where in the forum
Its realistic that windows could comfortably run from a 1gb card, once youve done either of the 2 options above. Ive seen it run on as little as 400mb of hard drive space
Once thats done you can them optimise it further by using 'Minlogon' all links are stickied here http://www.mp3car.com/vbulletin/winnt-based/
Have Fun![]()
LinkBack URL
About LinkBacks
