Results 1 to 2 of 2
Thread: CF card problems
    Aug 2004
    CF card problems
    I have a new transcend 4GB CF card. It says it supports both removable disk and fixed disk mode. When I try and install XP to it, it always says "could not find hard drive". I can see it as a hard drive in the bios. What am I doing wrong here?
    Also, I installed xp to a regular hard drive on the same computer then tried to transfer over all the files to the CF and tried booting it that way. Didn't work, said something about insert the right boot device.
    Please help! I'm not sure what else I can do. I found a program sandisk made to convert removable CF to fixed disk mode. It has a .com extension and I don't know how to use. I don't know why I would need to do that if my card supports fixed disk mode already. HELP!
    2004 Nissan 350z Daytona Blue
    2x 10" IDMax D4
    1250.1 kicker amp
    crappy dell carputer
    FLAC SFiorito's Avatar
    May 2004
    you should not install directly to the CF card. check the site in my signature for installation steps. if your card supports fixed disk mode you should check with Transcend how to enable it. the SanDisk utility will most likely not work since it's made for SanDisk cards (I don't believe SanDisk and Transcend use the same CF controllers).
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  1. Problems installing WiFi card
    By Coach_Ng in forum Wireless Communications
    Last Post: 12-22-2007, 04:28 PM
  2. Can't hibernate after transfer to CF card
    By blkwrx in forum Operating System Optimization
    Last Post: 02-08-2007, 08:47 AM
  3. read only win98 on a CF card
    By csnowman00 in forum Win 9x Based
    Last Post: 11-18-2006, 07:29 AM
  4. stuck on 'verifying dmi pool data' booting from a CF card
    By dyne in forum General Hardware Discussion
    Last Post: 08-11-2006, 10:48 AM
  5. a heads up for people looking for a CF card
    Last Post: 07-15-2006, 04:37 PM
