Can i run bootvis w/ EWF enabled?
It took a long time to get to this point and I'd be a real shame if I messed it up because I kind of only know what I'm doing.
I run bootvis all time under minlogon seems to run fine.
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
You must disable EWF to run bootvis. I doubt bootvis will harm your system but its always a good idea to make an image of your system using a backup software like paragon drive backup. In case of any hicups you can recover your system on under 1/2 hour.
Keep in mind like SFiorito said bootvis may not run in MicroXP....
After installing bootvis click on 'Trace"> "Next Boot + Driver Delays" you will be prompted to reboot.
After reboot bootvis will autorun (may take several minutes) and display some statistics, click on "Trace" > "Optimize System" you will be prompted for a reboot.
Once windows reboots, you will see a message optimizing system, this may take quite some time especially if this the first time you've run it.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
last time I ran bootvis with minlogon it didn't give all of the trace data....can't remember exactly what, it's been a very long time since I've used it... sorry...![]()
EWF, HORM, MinLogon on XP.
Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
Win Embedded Std 2011 RC
OCZ Vertex Turbo 30GB SSD
Lilliput 629 Transflective, WRX Screen Mount
BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
VoomPC 2
Do I need to tweak the registry entries to enable winlogon or is it just a matter of disabling EWF, renaming winlogon.exe.bak back to winlogon.exe and rebooting?
CarPuter Progress:
Cool. I'll give it a shot tonight or tomorrow. Still looking for a jumper pin so I can set my extra HDD as a slave to I can move my install to the 5400RPM HDD to see if that makes a difference.
I installed MicroXP but I didn't install EMF or HORM installed and I get into windows in 30seconds.
Hardware
VIA MII 10K
1 GB Ram
120 GB WD (5400rpm)
Bluetooth adapter (Belkin)
BU-353 (USB)
iFreedom Wireless Keyboard
M1-ATX
Software
Nero 7
IG 4
SlingPlayer
Word, Excel, Outlook 03
PowerDVD 7
Winamp 5.13
I installed MicroXP cause I wanted faster boot times also. I installed most of my apps but I have not installed RR yet. I wanted to see if I can get faster boot times by using bootvis before I added RR.
Gee
When I first installed MicroXP, i was getting "key on" to desktop in 22 seconds before installing all my usb/serial hardware & software.
Haven't had the chance to work on this, but I'm hoping bootvis can make a difference.
Still having trouble justifying the cost of an SSD, but the performance over my current HDD is undeniable.
