+ Reply to Thread
Results 1 to 10 of 10
Thread: New EWF & HORM manager tool
    May 2006
    Italy
    Lightbulb New EWF & HORM manager tool
    Hello,
    I have coded a small utility to simplify the handling of EWF and HORM features and I would like to share it.
    This utility, EWF&HORMmanager, (written with AutoIt v3, http://www.autoitscript.com/autoit3/) can be used to enable/disable EWF and HORM (on the system disk only): it's a GUI for the "ewfmgr" command line program. Moreover it can be used to unmount the disks not EWF-protected and to start the hibernation process.
    In order to use EWF&HORMmanager you should have installed properly EWF & HORM tecnologies from XP Embedded Feature Pack 2007.
    The included program "hibernate4HORM" is derived from source code published by Microsoft (http://msdn.microsoft.com/en-us/library/aa460084.aspx); it's used by EWF&HORMmanager to lock and unmount the EWF-unprotected drives, to hibernate the system and then (at resume time) to unlock the drives.
    I know that there is almost another tool doing the same thing, the HORM Manager Lite from Wechsler Consulting, but I found some problems running that tool with XPe FP 2007 and I would like a simpler GUI...
    Hope this can be useful to someone...
    huge63
    Attached Files Attached Files
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I'll try it out, looks very handy.
    Jun 2007
    St. Louis
    nice...one problem though. I tried running it on my carpc setup and I get the error saying I need xpepm tool. Is this in the xpe packages somewhere?
    Also, I'm running server 2003 if that makes any difference.
    May 2006
    Italy
    I'm sorry, I forgot to say that EWF&HORMmanager requires xpepm.exe and xpepm.dll from Windows XP Embedded SP2. You should take tham from the binaries catalog of the evaluation version and put them in C:\WINDOWS\System32...
    huge63
    Constant Bitrate almera's Avatar
    Aug 2004
    Seems very useful, thanks, I'll try it out..
    May 2006
    Italy
    EWF & HORM manager tool update
    I forgotted to disable "horm.dat" flag file when disabling HORM, so "normal" restore from hibernation file was not possible. In version 1.1 HORM disable renames the flag file, so that it's possible to use HMRM... :-)
    huge63
    Jun 2003
    Memphis - TN
    Quote Originally Posted by huge63 View Post
    huge63
    Any possibility that these can be posted? gonna be a pain just to download/install to get 2 files.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jan 2006
    bump... i can't find the files anywhere in the sp2 eval kit
    Feb 2008
    Here are all the ewf - horm files you should need
    HERE ARE ALL THE EWF - HORM FILES YOU SHOULD NEED
    I take credit for none of this.
    I can't provide any support, I barely understand it myself.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Thanks for this share
+ Reply to Thread
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  2. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
