fbwf booting from readly only
anyone know fbwf support booting xp on read only media? When tried that out the boot just met error 0x00000ED and restart and boot and again. the problem is not that on normal hardrive but present in read only media. EWF and fbwf both direct to ram and no write so why fbwf not possible to boot in read only media? lready delete the bootstat...
Bluescreen and other mistakes - pls give here what you know pls!
Hi!
First - the WBF and FBWF do not wish to cooperate wit my WINXP PRO SP3 German version, if i activated RAMDISC. I tested many versions, but will not work. OK, what can i do, i tried to test it withot Ramdisc.
Those way was bad too: FBWF with completely installed computer (GData AV, FarCry game and other soft) was not able to activate the FBWF absolutely. I have made the settings in the FBWFMGR, (threshold was set up on 1024 MB !!!) then verified those - all right, it say to me, taht after rebood will FBWF activated and so far ... BUT! After reboot was FBWF not activated like before, and the list of parameters was the same ... after reboot will be activated bla, bla...
If i does the threshold RAM value smaller to 256MB - the after each reboot i got a BLUESCREEN before Win was started!
Then i had installed WINXP PRO SP3 german. NAKED - only unnecessary updates, no AV, no Ramdisc, nothing else only drivers for used hardware. And look that! After properly settings the FBWF manager was working! I can get from the list of buffered files and so far. BUT! If i try to DISABLE IT ... I got the bluescreen either immediately after i does this, or if i restarted the WinXP. (I think, if i wish to made persistent changes, or install new programm to C:, it is necessary to disable the FBWF driver for this time and later enable it again. But this way was wrong again - not one time i had luck to disable before enabled FBWF driver!!! I cannot do more, because on theis Windows is installed only that, wahat i need to run it on this motherboard.
Any idea to made this working! Is it a new version of this software, what is working better as those from the MS Embedded SP2?
Thank you - if anyone have succesfulöly worked with FBWF driver, pls try to help me!
Bb, Feri
Can not disable FBWF anymore
Hi folks
I've got the same issue as Martijn which means my FBWF is working fine on a WinXP prof SP3 but when I try to disable it or make any changes I got a blue screen.
Anyone knows anything about that.
I appreciate any good answers.
Thanks.
