for those of you who dont know what FBWF is...its File Based Write Filter Driver.
http://msdn.microsoft.com/en-us/library/aa940926.aspx
Hi there. my first post, hope its of use to people here. I am using FBWF on a standard Windows XP Pro installation (SP3 RC1 to be exact). Finding no guide available online, I thought I'd write this one.
--EDIT--
Quick note for those of you who don't know what FBWF is. It is very similar to EWF, but FBWF (file based write filter) offers some important advantages. FBWF uses less ram (you can reclaim ram overlay space when you delete files), you can also commit on the fly (without restarting or disabling), and have persistent (write through) folders that write straight to the drive (so you can have a persistent My Documents for example).
--EDIT--
You will need the following files from the XPe feature pack 2007 trial.
fbwf.sys fbwfdll.dll fbwflib.dll fbwfmgr.exe
If you're not sure how to extract these files, please see the "New EWF + MinLogon and CF instructions" thread by SFiorito.
1.Copy fbwf.sys to \WINDOWS\system32\drivers
2.Copy all other files to \WINDOWS\system32\
3.Add the following to your registry (it's probably easiest to copy it into an empty txt file, rename it to fbwf.reg, and load)
4.RebootCode:Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\FBWF] "Start"=dword:00000000 "Type"=dword:00000002 "ErrorControl"=dword:00000001 "ImagePath"=hex(2):73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,44,00,\ 52,00,49,00,56,00,45,00,52,00,53,00,5c,00,66,00,62,00,77,00,66,00,2e,00,73,\ 00,79,00,73,00,00,00 "Group"="FSFilter System Recovery" "DisplayName"="File-Based Write Filter" "Description"="File-Based Write Filter driver" "DependOnService"=hex(7):46,00,6c,00,74,00,4d,00,67,00,72,00,00,00,00,00 "DebugFlags"=dword:00000000 "EnabledOnAllSkus"=dword:00000001 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\FBWF\FBA] "EnablePostFBA"=dword:00000001 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\FBWF\Instances] "DefaultInstance"="Fbwf Instance" [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\FBWF\Instances\Fbwf Instance] "Flags"=dword:00000000 "Altitude"="226000"
5.Go to your command prompt, and type in the following commands.
fbwfmgr /enable
fbwfmgr /addvolume X:
fbwfmgr /setthreshold S
X is the drive you want to protect (most will want to protect c. S is the size you want your ram drive to be in MB(mine is 256).
6. Reboot, and your done!
There are 4 other commands in fbwfmgr you may want to play with. /setpreallocation 1 reserves the ram space (I.E does not dynamically change with the amount of actual used space). /setcompression 1 compresses the date to save more ram space, but at the cost of CPU time. /overlaydetail tells you what files are being stored in ram, and how much ram space is being used. /addexclusion X: "\persistent\folder" enables write through on the folder X:\persistent\folder.
For those used to EWF, unfortunately there is no way to commit all data, and each file has to be committed manually with the following command /commit X: "\windows\file.exe"
I hope I haven't left anything out! Hopefully this guide will be usable and somewhat clear...and if it breaks your puter, well, I'm sorry :P
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog...needs updated)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: removed
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) removed
so you use FBWF instead of EWF?
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
Indeed, and I think its a lot better.
The main reason I use FBWF is that it uses MUCH less ram. You can also commit on the fly (without restarting or disabling), and have persistent (write through) folders that write straight to the drive (so you can have a persistent My Documents for example).
Here's a quote from "windowsfordevices.com"So basically...lets say you use EWF, and download a 30MB video, and then delete it, the 30MB of ram space you used does not get reclaimed. With FBWF, as the protection is at the file system level, you can download a video, delete it, and your ram use won't have gone up.EWF blindly filters all sector reads and writes. Since FBWF hooks in at the file level, it can perform intelligent filtering based on files, folders, or any file system data structures. It can also do a much better job reclaiming memory.
Riz
Im am currently running ewf on a 2G USB flash drive. Can i upgrade my ewf to Fbwf, How?.
Yes you can, simply turn off EWF (by removing the registry settings you applied to install EWF), and follow my instructions as listed.
now lets say I use a CF card as my hard drive, and set up FBWF, will this protect the card and make it last longer? well, let me rephrase that, how much longer/what time frame should this card last for
thanks alot!
Well, I was excited as all hell about using FBWF instead of EWF! Until I read about the inability to commit all changes immediately. That freaking blows chunks. It may be possible for one to read and parse the list of files output by /overlaydetail, file by file, but that's really hackish! Isn't there a built-in switch to do that? Gah...
At any rate, it looks like my "commit and disable" script needs a little tweaking
Thanks for the guide!!
edit: Screw it. I took the initiative myself.![]()
No problem Falcon, glad to help. If you could make a commit all script, that would be amazing. I've read a few posts from people online that seem to suggest that the FBWF API is easy to work with, so I say go for it! I'd give you a hand but I can't program to save my life lol.
Vip3r, the main purpose of FBWF and EWF is not so much flash memory wear (according to my calculations, even if you wrote to one 24/7, it would take at least 6 years before modern flash memory with 100,000 rewrite cycles would fail), but rather to speed things up alot, as flash is very fast to read, and very slow to write.
FBWF offers all the protection EWF does. I.E if you were to never commit any data (that is to say, never wrote any data to the flash apart from the first time you copied your Windows onto it), the flash should last a lifetime.
Riz
A couple more differences between EWF and FBWF, might be relevant for some users, from the MSDN site http://msdn.microsoft.com/en-us/library/aa940813.aspx.In addition, only EWF may be used with Hibernate Once Resume Many (HORM). HORM is not available when FBWF is used.
FBWF does not provide the following EWF functions:
* Support for multiple overlays
* Support for disk overlays
* Live commit and disable
