Results 1 to 5 of 5
Thread: Issues with HORM - Prompt at startup
    May 2005
    Toronto, ON
    I am trying to get HORM to work correctly, however I get this prompt when booting up after resuming from hibernation on the 2nd, 3rd, 4th, etc... time.
    The last attempt to restart the system from its previous location failed.
    Attempt to restart again?
    Delete restoration data and proceed to system boot menu
    Continue with system restart
    If I select the 2nd option, HORM works correctly. EWF and HORM works OK. I'm just trying to get rid of this prompt. Any ideas? I've deleted the bootstat.dat file already. Any help would be appreciated.
    Feb 2009
    how to disable HORM boot prompt
    Hello,
    I have copied horm.dat(one that is not empty) and resmany.dat (just in case).
    I have started EWF RAM succesfully on disk C, discs D,E are not protected (one HDD).
    Windows XP Pro is starting nice <1min.
    Hibernation is fast, returning from Hibernation state is so damn fast <30s. I am so glad.
    My problem is when I enter Hibernation state, then I startup PC for the first time, it wakes up in <30s.
    I switch it off (power suppy), start it again, and there is a prompt during boot process asking for me to choose:
    Continue - starts from last state (wakes up from hibernation state)...
    It is nice... how is it possible to disable this boot prompt?
    Please help me... maybe I am doing something in the wrong way.
    Best regards,
    MarekJ
    Mar 2007
    bump need an answer, tired of my keyboard being on the pass seat....
    FLAC SFiorito's Avatar
    May 2004
    did you delete the bootstat.dat file?
    http://granturing.blogspot.com/2007/...ginal-ewf.html
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    bump
    I'm having the same issue. I noticed that if i put in just the resmany.dat file, that it prompts me every boot excluding the first resume. But when I add horm.dat to the root, it just boots like it normally would, not even attempting to resume from hibernation. which leaves me to believe its an issue with the horm.dat. i noticed syscorp said "I have copied horm.dat(one that is not empty)".
    should horm.dat not be empty? i just have an empty text file...
    also, i didnt delete bootstat.dat, but i renamed it as bootstat.dat.bak, which should work regardless correct?
  1. volumn control for navigation prompt
    By E90FANS in forum Road Runner
    Last Post: 07-25-2008, 02:25 AM
  2. CF 2.0 RC3: Bugs / issues / suggestions
    By johnk in forum Centrafuse
    Last Post: 06-22-2008, 01:57 PM
  3. HORM without EWF
    By FX35 in forum WinNT Based
    Last Post: 04-22-2008, 08:53 AM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
  5. Replies: 0
    Last Post: 06-14-2004, 11:36 PM
