Results 1 to 10 of 13
Thread: Minlogon
    Jun 2008
    Minlogon
    For the instruction with Minlogo I have to install the trial of XPE and pull it out, is there a easyer way to do this without screwing up my install of xp right now? My setup right now is just a normal copy of XP because I keep it in hibernate anyway so It rarely gets restarted so the bloating isn't that big of a problem but Id like to skip all the welcome screen and stuff.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    You can grab the minlogon files from http://thuun.boot-land.net/index.html so you don't have to download xpe and go through that rigmoral, however if you just want to log on automatically when booting, take a look at http://www.microsoft.com/windowsxp/u...ips/knox2.mspx
    I installed my carpc into my pet Kangaroo, mate.
    Jun 2008
    Ok on the instructions it said
    Next modify the registry on the XP system by changing the "Config" value in the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon key to be 0x17.
    Which file in the Winlogon area am I changing to 0x17?
    Nov 2006
    You don't need to manually change anything. Just double click the registry file included in that download. It will ask you to confirm, select yes and it will make the changes for you.
    Make sure you rename winlogon.exe to winlogon.exe.bak in the system32 folder, copy minlogon.exe from the download to the system 32 folder and then rename it to winlogon.exe before restarting.
    Jun 2008
    There is no registry file with the download.
    Just the minlogon.inf and the minlogon.exe
    Nov 2006
    Ahh bugger, it used to have it in there...
    Try this:
    Create a file called minlogon.reg and using notepad copy the following text:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "Config"=dword:00000017
    Save the file and run it. Now the reg entries should have been imported.
    Jun 2008
    Ok restarted but it didn't seem like it did anything? Should my welcome screen still come up?
    Nov 2006
    No, your welcome screen shouldn't come up.
    Make sure you do the following:
    - Goto windows\system32 and rename winlogon.exe to winlogon.exe.bak
    - Copy minlogon.exe from the download to windows/system32/
    - Rename minlogon.exe to winlogon.exe
    - On your desktop, create a .txt , open it and copy the following text:
    - Save as minlogon.txt
    - rename minlogon.txt to minlogon.reg
    - open minlogon.reg and click yes when it asks for permission
    - Reboot.
    The first time you reboot it will be slow as it builds the user account, after that it should be a little quicker
    Jun 2008
    Everytime I rename winlogon.exe it creates a new one.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Turn off Windows File Protection.
    http://www.pctools.com/guides/registry/detail/790
  1. Replies: 268
    Last Post: 05-28-2012, 09:49 AM
  2. My experience with Minlogon and CF
    By Spawn12336 in forum Operating System Optimization
    Last Post: 01-24-2008, 12:38 PM
  3. Problems shutting down with minlogon
    By RedGTiVR6 in forum Power Supplies
    Last Post: 09-21-2006, 09:19 AM
  4. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 05:18 AM
  5. Minlogon & Hibernation - Possible fix
    By Gobby in forum WinNT Based
    Last Post: 04-04-2005, 04:06 AM
