Results 1 to 10 of 13
Thread: HOWTO: Modifying "Resuming windows" hibernation screen
    Dec 2008
    After reading excellent posting about customizing text and bitmap on the "resuming windows" screen, here: Customizing the "Resuming Windows" screen, I made an extra step forward and found how to get rid of the ugly progress bar.
    This progress bar is made of characters 0xDB (full) and 0xDE (empty) from system "Terminal" font. All you need to do is:
    - Open "C:\ntldr" in binary editor (see the post above on how to do it considering attributes, safety and write protection).
    - Scroll down until you reach the area with all the text messages (it's in last 10% of the file, typically starting with "Windows could not start...").
    - From that point on - look for DB and DE hex characters (WARNING: the characters should be very close to the end of file, about 100 bytes from the end; don't let the editor to restart search from the beginning of the file)
    - Replace both characters with single space
    - Save, replace the system original "ntldr" and enjoy - you now have pure-plack resuming screen!
    Mar 2008
    Australia
    Tried it out tonight and it worked perfectly, now my resume from hibernation is completely black!
    Newbie Kadyroff's Avatar
    Sep 2007
    Moscow, Russia
    i believe this thread deserve to be sticked!
    project progress:
    Planning.......[--------X-] – 90%
    Parts............[-------X--] – 80%
    Fabrication....[------X---] – 75%
    Installation...[-------X--] – 80%
    Worklog
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Thats cool. I'll give it a try
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Elsewhere
    If not done correctly, this is a good way to completely hose your Windoze install.
    Use extreme caution.
    How about the Wiki?
    Jun 2003
    Memphis - TN
    Doesn't work with EWF NTLDR
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Vendor - Qube colin's Avatar
    Dec 2006
    It probably does. The EWF NTLDR uses the same font and displays the exact same loading bar, you probably just modified the wrong spot. It could be in a different location in the EWF file.
    May 2008
    Or EWF is doing what EWF does and the updated file is not getting written to the physical disk. Are you committing the changes to the protected volume?
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    I've had the same issue with EWF turned off.
    I have bad luck with vehicles...
    Dec 2006
    Have you guys tried modifying it before copying it over? I mean modifying the EWF NTLDR on a normal system and then copying it when you do your install.
  1. Customizing the "Resuming Windows" screen
    By davem in forum General MP3Car Discussion
    Last Post: 01-10-2011, 04:53 PM
  2. Replies: 58
    Last Post: 05-14-2009, 09:21 AM
  3. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  4. touch screen quits after hibernation
    By cybuch in forum Input Devices
    Last Post: 09-27-2006, 12:48 PM
  5. HOWTO for Lilliput Touch Screen for Linux
    By turbodog00 in forum Newbie
    Last Post: 09-26-2004, 01:07 PM
