Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: HORM for dummies?
  1. #11
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by SFiorito View Post
    what problems are you having? yes, you can have multiple partitions. however, you need to unmount the other partitions when you hibernate so that the write cache is not saved with the hibernation state.
    I currently have a similar setup where I have the OS on the EWF/HORM partition and my FE(Road Runner)/Winamp on the other.
    The new carPC is still being bench tested, so I haven't fully enabled/tested EWF/HORM and hibernate/resume w/ my FE yet.
    After much research, I did it this way to have a stable hib file and so my FE can pick up where it left off, which is read from an ini file that is updated when hibernating. I didn't read/find anything about "unmounting" a partition prior to creating the hib file when using EWF/HORM on another partition.
    Could you please explain this? I would greatly appreciate it.
    TIA!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #12
    FLAC SFiorito's Avatar
    May 2004
    yes, you need EWF in order for HORM to work.
    See my site for instructions for both.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  3. #13
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    I found a problem yesterday that sounds just like that. I use a dinovo mini keyboard. I normally keep it paired with the internal bluetooth so I can keep the dinovo dongle free for my HTPC when needed (2 dinovo's, one dongle). However, I wanted to test it out by using the dinovo dongle kept in. It was plugged into a d-link powered 7 port usb hub. I kept noticing that it would go into hibernation fine, but when I would start up, it would be a cold boot.
    Found that after it went into hibernation, something with the dongle would wake it back up (probably legacy USB support that I leave on for emergencies). After it came out of hibernation, then it would shutdown cold. Removed the dongle, and everything was yipee skippy again.
    My opinion is my own.
  1. New EWF & HORM manager tool
    By huge63 in forum WinNT Based
    Last Post: 01-14-2015, 09:02 AM
  2. Issues with HORM - Prompt at startup
    By BikeBoy24 in forum WinNT Based
    Last Post: 05-28-2009, 11:01 AM
  3. HORM and RR : How does it work ?
    By Konrad in forum Road Runner
    Last Post: 01-23-2008, 08:29 AM
  4. Question about SD and HORM
    By Snoobaru in forum StreetDeck
    Last Post: 09-04-2006, 10:49 PM
  5. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
