Results 1 to 10 of 13
Thread: HORM for dummies?
    Dec 2008
    HORM for dummies?
    I'm having som hibernation/resume problems, and was thinking that HORM might be the answer.
    My system has a single 2.5" HDD, with two partitions.
    Can i use HORM on the boot partition without making changes to the 2nd partition? Or do i need 2 drives?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    HORM will work fine regardless of your partition setup.
    What kind of hibernate/resume issues are you having?
    FLAC SFiorito's Avatar
    May 2004
    what problems are you having? yes, you can have multiple partitions. however, you need to unmount the other partitions when you hibernate so that the write cache is not saved with the hibernation state.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Dec 2008
    Quote Originally Posted by Machinehead View Post
    Ok, I thought that I needed some kind of write protection that would make my non-system partition useless.
    My system is set to hibernate on ignition off (+ power button & sleep button).
    But the system does a normal boot ~60% of the time, pretty random. There does not seem to be any connection to the off time of the car.
    Dec 2008
    Quote Originally Posted by SFiorito View Post
    Is there some where I can find an easy guide to HORM?
    Jun 2007
    Quote Originally Posted by Smartass View Post
    The first thing that comes to mind is that your system isn't completing the hibernation process prior to your power supple cutting off power. But I don't know how your system is set up and exactly what it's doing.
    Dec 2008
    The PSU is set to 5 sec. to shotdown signal, 45 sec. to hard off.
    Jun 2007
    That should be enough unless your system is hanging for some reason.
    Dec 2008
    I get the screen power from ignition (my battery got drained). So I can't se if the problem is when it writes the hibernation file.
    Dec 2008
    I tried lookin into your link, it seems to me that i do infact need EWF to use HORM?
    Quote Originally Posted by http://granturing.blogspot.com/
    All it takes is a simple file called “horm.dat” on the root of your drive. Just create a simple textfile and rename it. When it’s present on the root drive, the EWF NTLDR knows not to reset the hibernation file...
  1. New EWF & HORM manager tool
    By huge63 in forum WinNT Based
    Last Post: 01-14-2015, 09:02 AM
  2. Issues with HORM - Prompt at startup
    By BikeBoy24 in forum WinNT Based
    Last Post: 05-28-2009, 11:01 AM
  3. HORM and RR : How does it work ?
    By Konrad in forum Road Runner
    Last Post: 01-23-2008, 08:29 AM
  4. Question about SD and HORM
    By Snoobaru in forum StreetDeck
    Last Post: 09-04-2006, 10:49 PM
  5. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
