Results 1 to 7 of 7
Thread: Very slow CF reads... what's the problem?
    Constant Bitrate Outsider787's Avatar
    May 2006
    I'm setting up my second carpc.
    I'm using a VIA EPIA M1000 mobo with 1 gig of ram.
    I've installed a lite version of XP (created with nLite) on a regular HD, with both EWF as well as MinLogon.
    The system boots very quickly off the HD. about 10-15 sec untill windows is usable, and another 10-15 till Road Runner is fully usable.
    I'm very happy with those numbers.
    I then copied the entire HD to a 4gig CF card, with room to spare.
    When I boot off the CF card, it takes forever. I haven't timed it but it's easily 10 times slower.
    The CF card is a Kingston Elite Pro 133X card. The CF to IDE adaptor is something I picked up on ebay a couple of years ago.
    Could it be that the CF to IDE adapter is causing this dramatic slowdown?
    If so, any recomendations on a fast CF to IDE adapter?
    Mar 2006
    Colorado, but Canadian!
    Yes the adapter could be bottlneck, but I think you have other issues.
    That card has a max transfer read speed of 25Mb/s and max write of 20Mb/s.
    ATA100 from before the new millenium is 100Mb/s, ATA133 is 133Mb/s. SATAI is 150Mb/s and SATAII is 300Mb/s.
    I think there is your bottlneck.
    A CF card is never for speed. It is for durability.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC SFiorito's Avatar
    May 2004
    use only CF adapters from logicsupply.com or addonics.com
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by Outsider787 View Post
    You could try changing the IDE adapter, but, I don't think it will help much. Compact flash cards are slow when used for loading an operating system. The particular card you have operates @ 20Mb/s read and write, which is consistent with your findings.
    If you put 4 of them in RAID0, you just might see a performance increase. However, I doubt it will be worth the money compared to the VelociRaptor hard disks, or an Intel SSD.
    If you insist on CF, then try Lexar. They make the fastest CF @ 300x, with 45mb/s transfer speeds. It will set you back $180, nevertheless, it's a lost cause, better left for the high end digital camera market at which they were intended for. The Lexar 300x is still much slower than most of today's standard hard drives.
    Aug 2008
    Make sure the drive is in the higest DMA (or if it doesnt support DMA, PIO) mode it supports. Using HDTach or another program, what kind of throughput are you getting?
    DLe
    DLe is offline
    Constant Bitrate DLe's Avatar
    Mar 2004
    outsider787: did you ever find out what the issue was? im in the same boat with (probably) the same hardware (ide2cf-a1 adapter, 8gb kingston elite pro 133x CF card). it boots fine to the blue screen before windows but then takes about a good 5 mins to boot explorer.exe so i don't see anything until about 8 mins after reboot!
    any help would be appreciated. thanks!
    May 2005
    Stockholm
    I also did the big mistake to buy a 8Gb Kingston Elite Pro 133X. When I copy over the files during the installation of XP it went okey but when I come to the installation it took ages. When I finaly was ready (after several hours of installation) it worked but the boot took ages and the system was like freezing some times.
    I then bought a transcend extreme speed 4Gb instead (300X). Then it workes without any problems. It was the kingstone Elite Pro card that is not possible to use as a hard drive.
    I think it has to do with what kind of memory they are using. Transcend is using SLC and Kingstone elite pro is probably done with MLC. Kingstone Ultimate 266X card is probably working okey. They are also using SLC.
  1. menu items missing after install CF 2.0
    By vqstatesman in forum Centrafuse
    Last Post: 02-09-2009, 02:26 PM
  2. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 02:59 PM
  3. Extremely slow CF (IDE)
    By Leonichol in forum General Hardware Discussion
    Last Post: 03-14-2008, 02:31 PM
  4. CF redraw speed... slow?
    By justintime in forum Centrafuse
    Last Post: 08-18-2006, 01:48 AM
  5. FV24 slow boot problem
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-24-2002, 09:09 AM
