Results 1 to 10 of 12
Thread: Image HD and load to CF
    Apr 2009
    I have created an XP Home image using NLite and setting up ewf and everything I need on an NTFS 80GB IDE HD (using 1.2GB). I have a VIA EPIA EX 15000G motherboard with 1GB of RAM and a CF to IDE adapter installed on it. My question/problem is how do I get the image off of my IDE drive and onto my CF drive.
    I formatted my CF drive in Vista as NTFS. I have plugged the IDE drive into my Vista PC as a slave and tried copying all of the files over to the CF drive. That didn't work. I've read a ton of guides on this and I feel like I'm missing something obvious. I have purchased Norton Ghost for my Vista PC, but not sure how deploy the image to the CF drive using that.
    I tried searching, but a lot of the threads that came up had hundred and hundreds of replies and I didn't see what I was looking for when skimming through. Thanks for the help!!
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I have used WinImage seams to work fine for the smaller images
    but I have use it for larger ones, I have also used FlashBoot, its a little
    more flexible tad bit less reliable, Also WinDD or DD in Linux, there
    command line tools, You could also try Selfimage
    WinImage has worked the best for me, quick and easy, but it does not always
    work, sometimes I have to use WinDD or DD
    Another tool that might be fun to play with is UNetbootin, but its for
    putting Linux images/iso on flash drives
    I just hope one of them works in Vista
    Good Luck
    FLAC SFiorito's Avatar
    May 2004
    using a PE disc (WinPE or BartPE) with imagex is the easiest way for me. I have a dedicated WinPE thumbdrive that I've used hundreds of times for these types of things.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by SFiorito View Post
    I wonder if he could also just copy the files over and then use
    BootPrep to make it bootable like you would on XP Embedded
    May 2004
    yes, he can. in fact that's how i recommend doing it in my EWF guide. when I wrote the guide there was no imagex, so xcopy was the easiest.
    VoomPC 2
    Apr 2009
    Well I purchased Paragon Partition Manager which imaged my HD to my CF card, but CF card still won't boot, just runs through bios, goes to Verifying DMI Pool Data... and then nothing. HD activity light is solid though. Not sure what's going on?
    You think even though I imaged from one HD to another that i need to use bootprep still? Is there a better way to troubleshoot why it's not booting? Thanks again.
    UPDATE
    I have tried both the older style ATA cables and newer style, I have tried on both the master and slave portions of the cable and have also edited the BIOS to try CHS, LBA and Large, all with NO success.
    Also my CF card is a SanDisk Extreme III 4GB card and it is detected properly in the BIOS. This is the CF to IDE adapter I have http://www.casetronic.com/product_d.php?id=0000000044
    Dec 2005
    Raleigh, NC
    I've used DD in Linux for years to do this. It doesn't matter what the drive is, it just makes an image and you can save it or write directly to the CF card.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
    Aug 2008
    I've had some problems with Ghost-ing from one drive to another, with Vista as the booting OS. XP, never a problem, but Vista needs to do a quick automatic repair (after booting from the CD, of course) in around 90% of the computers which I migrate, upgrade, or replace the HDD, and salvage the data with Ghost.
    Also, best fix might be to make a .gho image, not a d2d clone whenever this bootup occurs.
    Apr 2009
    Ok finally got XP running on my CF, but it takes and no exaggeration here, probably over an hour to boot up. Speeds are fine when it is running, but my goodness it is ridiculously slow on boot up.
    Any ideas?
    May 2004
    what CF card and CF-IDE adapter are you using? have you considered using an SSD instead? much better performance and usability for the price.
    VoomPC 2
  1. Which EQ for HD radio?
    By ccrum in forum RR Skins
    Last Post: 06-24-2008, 11:26 AM
  2. Speeding Up SD Load
    By Caelric in forum StreetDeck
    Last Post: 06-21-2008, 08:28 PM
  3. Fastest CF card?
    By scsirob in forum General Hardware Discussion
    Last Post: 05-19-2006, 07:23 PM
  4. FS: M10000 Lilliput Slot Load DVD 60G HD
    By heefer12 in forum Classified Archive
    Last Post: 02-13-2005, 03:25 PM
  5. Slim/slot load DVD + laptop HD
    By cenwesi in forum General Hardware Discussion
    Last Post: 04-26-2002, 04:31 PM
