Results 1 to 3 of 3
Thread: Windows crashes when booting from CF
    Aug 2004
    Alright, I want to swap the harddisk in my CarPC with a cf card. I installed my CarPC on a virtual pc. I formated the cf card with FAT32 and ran bootprep. Then I copied everything over to the cf card. The system starts to boot, I can just see the boot picture appear, but then the system crashes/reboots. I tried to run the system in safe mode, but then it also just reboots.
    Did I miss something ?
    VIA EPIA M10000
    Bios Version 1.16
    512 MB RAM
    Transcend 300x 4GB cf card
    I got one of therse adapters: Yingstar Dual CF Compactflash adapter
    no other hardware attached
    P.S. The system runs fine with my harddisk.
    FLAC SFiorito's Avatar
    May 2004
    Try just with a boot.ini and ntldr on the drive and see what happens.
    Also, I'm willing to bet it's the CF Chinese adapters from ebay are notorious for misbehaving. I suggest LogicSupply, Addonics, or ACSControl.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Newbie SCIONology's Avatar
    Dec 2009
    Hickory NC
    when you try to boot in safe mode, what's the last file you see before it crashes?
    it's most likely that you installed win in vmware and transfered the image to boot of an actual pc, the hardware has now changed and win doesn't know how to use the new hardware (it's something that's only configured during initial win install)
    same scenario i once tried to take a hard drive that booted fine and put it into a different pc to boot off of it, it wouldn't boot and stuck at loading the mup.sys file. after doing research i learned the basic rule that unless the 2 pc's have almost identical mobo's and processors you can't swap boot drives.
    sorry but it looks like you'll need to reinstall win, but let me know what file it's crashing on.
    also you can download hiren's boot cd here and burn iso with included iso burning software, pop it in your carputer drive and go to hard disk or testing utilities and do a hdd scan to make sure the ssd reads and writes correctly. but i think it has more to do with software then hardware.
    Scion xB G2
    Planning: [----------]
    Parts: [----------]
    Install: [----------]
    My Scion PC Project (put on hold until I find a nicer host):
  1. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 08:31 PM
  2. Running CF on Windows Fundamentals?
    By Lum in forum Centrafuse
    Last Post: 04-27-2007, 12:29 AM
  3. Replies: 2
    Last Post: 09-04-2006, 04:52 AM
  4. Booting XP from mobo cf slot
    By tibby01 in forum WinNT Based
    Last Post: 03-19-2006, 01:46 AM
  5. Windows 95-98 networking + Windows machine booting in dos mode every time...
    By SkinnyBoy in forum General Hardware Discussion
    Last Post: 08-21-2001, 12:18 PM
