Results 1 to 4 of 4
Thread: How to automatically shutdown XP after it goes to standby?
    Oct 2009
    Hello and Happy New Year,
    I am building a carputer using my laptop. To make the long story short I like how easily the computer goes into standby and comes out of it once a pulse is initiated at the power switch. But I would like to have it shutdown after a certain amount of time when it is on standby. I know in XP's power options I can set a predetermined time for it to go into hibernation after it goes to standby. But I do not see the point to have it hibernate all night in the car wasting the laptop's battery juice when the boot up times are almost the same as the ones coming from hibernation. A shutdown option with time settings is not displayed in power options, so my choices are limited to standby and hibernate.
    Any help would be greatly appreciated. Thank you.
    Dec 2009
    You know hibernation draws 0 power? It's off. Just has a saved state to go back to on wake up. The 10 second start up to save state isn't going to waste much battery..
    Sorry if I missed the point to your post.
    Oct 2009
    Thank you for your response. I was under the impression that in hibernation there is current drawn from the battery.
    Thank you for clearing this up for me.
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Baritono View Post
    When you use Standby, it keeps the memory in RAM and therefore has to keep the RAM powered because it's volatile memory. With hibernation it takes the memory from RAM and writes it to the disk, then shuts down. When it wakes, it takes that information from disk and writes it back to RAM again.
    So no, when you use hibernation, your computer is off. There is no current draw.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  2. Hibernate automatically from standby?
    By jnorion in forum Operating System Optimization
    Last Post: 05-22-2007, 11:33 AM
  3. Shutdown controller
    By screwc149 in forum Power Supplies
    Last Post: 11-22-2006, 10:38 AM
  4. Replies: 8
    Last Post: 10-19-2006, 07:32 PM
