Results 1 to 7 of 7
Thread: Windows 7 Optimizations
    FLAC SFiorito's Avatar
    May 2004
    Starting this off with some simple stuff to have a "clean" start up look and feel:
    bcdedit /set bootux disabled (blank screen instead of animation)
    bcdedit /set quietboot on (no progress bars, even in resume from hibernate)
    bcdedit /set bootstatuspolicy ignoreallfailures (disable recovery console which is useless in the car, you shouldn't be BSOD'ing out anyhow)
    BCDEdit docs here: http://msdn.microsoft.com/en-us/library/aa906211.aspx
    USB Troubleshooting Tips:
    Using Event Tracing to debug USB issues: http://blogs.msdn.com/usbcoreblog/ar...ore-stack.aspx
    Fixing USB devices that don't work after system resume: http://blogs.msdn.com/usbcoreblog/ar...em-resume.aspx
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    May 2004
    antimatter found this good tip in order to reduce you hibernation file size. I'm copying and pasting from his post:
    if you have 2gigs of memory but only consistently use less than 1gig of physical memory type:
    powercfg.exe -h -size 50
    (50 being the percentage of total)
    This will make the hibernate file 1/2 the total physical memory which should speed up resume from hibernate times.
    Note that the minimum size you can set, according to MSDN, is 50%. More info here: http://download.microsoft.com/downlo...Footprint.docx
    VoomPC 2
    Apr 2009
    Newark, New Jersey, United States
    thank you guys
    very helpful
    Sep 2008
    Western Australia
    Quote Originally Posted by SFiorito View Post
    Awesome. No need to hack any system files like in XP. Will try it out, thanks!
    Oct 2006
    why not use less ram instead?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Punky View Post
    Because the would make sense
    Truthfully, due to memory fragmentation, you would have much better results using just a single gig of RAM
    May 2004
    since ram is cheap some people may have gotten more than necessary to give them enough wiggle room to expand. in reality, with a slimmed down OS ram usage is much lower. so this at least gives you an option to compensate for the unused ram in the event that removing physical ram isn't an option?
    VoomPC 2
  1. Windows 7 installation and lilliput 7" display
    By URAN in forum Software & Software Development
    Last Post: 10-03-2009, 01:37 AM
  2. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
