Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: EWF on Windows 7 32-bit or 64-bit (Enhanced Write Filter)
  1. #11
    Aug 2010
    Just thought of this, but is it possible that TRIM + EWF is corrupting my SSD?
  2. #12
    Jan 2011
    No, when EWF is enabled nothing can write to disk it's all comitted to the filter cache in RAM, and in RAM (REG) mod some data goes in the Registry as well... Don't feel patronized here, but, your second post implies you might installing games after you've enabled EWF? That just won't work, nothing can write to disk, and you may be getting registry corruption in the process if you're in RAM (REG) mode... You have to disable EWF any time you want to make any changes to your Windows installation and any game or software you want installed on your system; not doing so will crash and fail as many game installation are physically larger then the amount of RAM on many systems...
    =O/
  3. #13
    Aug 2010
    Quote Originally Posted by Waika View Post
    =O/
    That's the theory, and i know all that, having used EWF on XP for years. My point is under win7, when i install games, which is an example of changes much larger than my available ram, the system DOESN'T freeze and crash. It just slows down.
  4. #14
    Jan 2011
    If that's the case what's your issue then?
  5. #15
    Aug 2010
    Like i said, i suspect it has something to do with my drive corrupting and i've wondering if anyone has tried making changes that are larger than their ram without commiting.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  3. Vista 64 bit driver problem
    By Bigseven74 in forum Software & Software Development
    Last Post: 10-01-2008, 11:35 PM
  4. Full XP on USB,someone tryed this?
    By gradecak in forum Software & Software Development
    Last Post: 03-20-2008, 06:36 AM
  5. Core Duo/Core 2 Duo processors
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 02-06-2007, 08:00 PM
Tags for this Thread
