Results 1 to 5 of 5
Thread: EWF+HORM - unprotected partition
    Jan 2011
    Hi!
    I have EWF+HORM in my pc, but I have a problem, I hope in your help:
    my Hard disk have two partitions, I installed EWF+HORM on primary partition and work perfectly, but if I make changes in the unprotected secondary partition (example new file ), this not are present in the next boot, which are the problem?
    Thanks!
    FLAC SFiorito's Avatar
    May 2004
    Are you sure your second partition is not protected? Are you shutting down cleanly or hibernating?
    If you're using HORM then you need to unmount your non-EWF partitions before hibernating. See here for how to do it using diskpart: http://social.msdn.microsoft.com/For...7-d3940b370b50
    Or here for doing it programmatically: http://msdn.microsoft.com/en-us/library/aa460084.aspx
    I used to have a CLI tool to do this. Might still be available on the forums I think I posted it years ago.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Jan 2011
    Hi Silvio, thanks for your answer...
    The secondary partition (D) not is protected, the ArcName is only:
    multi(0)disk(0)rdisk(0)partition(1)
    I shutdown my pc simply unplug the power ac and reboot it always with the same image, work fine!
    I try the software diskpart.exe to modify file in my unprotected secondary partition, but if not work it i want protected the secondary partition with ewf+horm, which are the procedure for do it?
    I must add the info:
    multi(0)disk(0)rdisk(0)partition(2) ?
    The volume (0) is the same...
    Thanks!
    May 2004
    If you just pull the AC power then the write cache probably has not had a chance to flush to disk. So you could either disable write caching (check disk properties in device management), cleanly shutdown/reboot, or unmount the drive using diskpart as in the article above.
    VoomPC 2
    Jan 2011
    Hi Sfiorito, yes i unplug the Ac power to shutdown pc...
    I tried the software diskpart for write in secondary partition:
    but not work fine, if i want shutdown the pc unpluging the AC power the changes in secondary partition not there are present, the changes there are only if i hibernates the system again...
    you are sure that this diskpart work fine?
    If this diskpart not work fine i must disable write caching for not damage the file system of the volume?
    Last info:
    [HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ EWF \ Parameters \ Protected \ Volume0]
    "Type" = dword: 00000001
    "ArcName" = "multi (0) disk (0) rdisk (0) partition (1)"
    With this information in registry i protect only primary partition of volume0, but if i want protect directly all volume0 with all partition, which are the correct arcname?
  1. New EWF & HORM manager tool
    By huge63 in forum WinNT Based
    Last Post: 01-14-2015, 09:02 AM
  2. Replies: 27
    Last Post: 09-16-2009, 01:39 PM
  3. Quick Q on HORM and an Unprotected Drive
    By Sal R. in forum WinNT Based
    Last Post: 04-26-2009, 03:22 AM
  4. HORM without EWF
    By FX35 in forum WinNT Based
    Last Post: 04-22-2008, 08:53 AM
  5. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
