Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
Thread: quick, newbie friendly, 2000lite tutorial
  1. #41
    Jan 2004
    Sweden
    I found One really bad thing with this lite 2000. I installed everything, it was great. BUT when I installed Pivot Pro everything ****ed up, and I couldn't get into windows again!!
    Bad luck!
  2. #42
    Aug 2003
    San Diego, California
    looks like i'll be getting win2k from school, and not winXP.
    however, you guys are getting some terrible boot times.
    a fresh XP pro install on my comp gives a cold boot time from power on to usable desktop in 33 seconds. unoptomized. i havent even had a chance to run the black viper list yet.
  3. #43
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Please do share your specs.
    We are, will have and forever will be...
    But not tommorrow!
  4. #44
  5. #45
    Aug 2003
    Quote Originally Posted by AlienEclipse
    7200 rpm drive, 40 gig.
    mATX board.
    half gig sdRAM
    duron 1.8 ghz.
    nothing particularly exciting. i imagine my boot times will go down a little more when i switch over to DDR ram. (mobo supports both)
    i chose the duron cause it was the cheapest solution to reliable divx playing. i may go ahead and sell the duron in favor of a barton core mobile xp2400+, to go from 55 watts power consumption at full load to 45 watts. course, not much advantage from that... maybe i'll go after that mobile 2200+... 35 watts power consumption.
    whatever i do, i just need to get it under the 150 watts for the opus, with using a slot load dvd drive. I dont really know what i'm at now... i'm running it on a 180 watt sparkle branded emachines form factor power supply.
  6. #46
    Aug 2003
    I knew it!
    dropped the boot time to 29 seconds with the addition of DDR as opposed to SDRAM.
  7. #47
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    whats the best/cheapest way to get windows 2000
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
  8. #48
    Aug 2003
    cheapest way = download it.
    best way... probably through a college student through a school for significant discount.
  9. #49
    Aug 2003
    i tried this today and had no luck. i created the boot cd after replacing the old files with the pre-modded files. the boot cd worked fine. however, after the installation copies the files to my computer and starts windows to complete the installation, i get a product key not found message. It never asks me to put in a product key and just gives me an error. When i use the original windows 2000 cd to install, it goes through fine and then prompts me for the product key. please advise?
  10. #50
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    How possible is it to boot from compact flash? I got an epia MII 12000 and just wondering if I put the OS on the flash, everything else on the HDD because I think that flash can only be written 10000 times before crapping out.
