Well I had to mention I do not use hibernation and virtual memory. If you do the same, you can start with deleting hidden file in your root directory called "hiberfill.sys". Then its only cosmetics. I delete all INF files from your Windows dir (called OS in my case), TXT, LOG files... and OOBE, WEB, HELP, SYSTEM folders... all the junk left by nLite, such as DOS enviroment in System32...
LinkBack URL
About LinkBacks
