Yeah, unfortunately that seems to be one of the side effects of minlogon. I would recommend to run bootvis trace as the last thing you do before minlogon (after you install all your drivers, apps, etc.) so then you can see what's slowing you down, take care of it, then install minlogon.
LinkBack URL
About LinkBacks
I'm not the only one that has successfully accomplished this. I just want to make sure: you run "sfc /purgecache", "sfc /cachesize=0", then RENAME winlogon.exe, wait a few seconds to see what happens, then copy minlogon.exe over? I know one time it recreated winlogon.exe, but I was still able to copy minlogon.exe over and it stayed. If you simply delete it SFC will correct it automatically.
