Page 15 of 27 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #141
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Quote Originally Posted by FetLyd
    Weird... Let's try again!
    FetLyd, does your exe contain compressed versions of minlogin and ewf, or do you need them seperatley?
    4x4 in a turbo stylee.
  2. #142
    Jun 2004
    No, it doesn't contain any files.. You'll need to place them like i wrote in one of the earlier posts..
  3. #143
    May 2002
    Warrington UK
    Thanks.
    Was just going back through the posts then realised I had done anything before building the image, other than unzipping your $OEM$ folder, left it doing an unattended install on my test VMware this morning before I left for work. Damn, how stupid. that's going to work well.
    Good job, I can at least see how small the base Nlited install is, if the missing files haven't fubared the install.
  4. #144
    Jun 2004
    Hehe! Please give me some feedback when you know how it works..
  5. #145
    May 2002
    Warrington UK
    I will do, because I have the XPe developer/trial/demo pack thing installed.
  6. #146
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    My computer that I have been testing this with has no password on startup before the changes. After running the Fetlyd.exe program (accidentally kind of) it now boots up with the w2k style login but hangs and asks for a username and password. I have tried everything but cant get past it. Is there password set during this install?
    It isnt a huge deal, but would be nice if I could get back in to recover some stuff from the last few days
    2005 Ford Focus ST
  7. #147
    Dec 2003
    Portland, OR
    ..nevermind...I guessed it
    That'll teach me to set my machine to single click!
    2005 Ford Focus ST
  8. #148
    May 2002
    Warrington UK
    OK, minlogin worked sort of.
    XP Pro Corp with a streamlined SP2 using Nlite.
    Downloaded fetlyd.zip and EWF.zip
    for the minlogin stuff,
    put commandlines.txt and fetlyd.reg in $oem$
    put fetlyd.exe minlogon.exe and minlogon.reg in $oem$/$$/system32
    Then created and installed the Nlited ISO onto a VMWare virtual box.
    It only installed XP as normal , and on a reboot carried on using winlogon.
    I had a look through the registry for the fetlyd.exe in the runonce keys, and nothing there.
    fetlyd.exe was in the system32 folder, so I ran it by hand and it over copied the winlogon correctly.
    Rebooted and I now have a fairly quick minlogon booting into the system account.
  9. #149
    Jun 2004
    Skraggy_uk : How does your commandlines.txt look like?
  10. #150
    Jun 2004
    Quote Originally Posted by gospeed.racer
    The program I threw together does not set any passwords.. Actually, with MinLogin, i think you should'nt have gotten that login screen at all.. Anyways, good thing you figured it out..
