Page 16 of 27 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #151
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    At work ATM, but off the top of my my head I didn't change anything from the Zip when I unzipped it into the root of my Nlite build folder
    [COMMANDS]
    "REGEDIT /S fetlyd.reg"
    4x4 in a turbo stylee.
  2. #152
    Jun 2004
    If anyone wants the source for fetlyd.exe, here it is.. Coded in Delphi 4.. Please don't laugh!
    Code:
    program fetlyd;
    uses
      Windows, SysUtils, Classes, Forms, registry, shellapi;
    {$R *.RES}
    var
      Reg: TRegistry;
      L1: TStringList;
      X: Integer;
      S: String;
    begin
      Application.Initialize;
      renamefile(extractfilepath(application.exename)+'winlogon.exe', extractfilepath(application.exename)+'winlogon.bak');
      renamefile(extractfilepath(application.exename)+'minlogon.exe', extractfilepath(application.exename)+'winlogon.exe');
      try
        Reg := TRegistry.Create;
        L1 := TStringList.Create;
        Reg.RootKey := HKEY_LOCAL_MACHINE;
        if Reg.OpenKey('\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon', True) then
        begin
          reg.GetValueNames(L1);
          For X := 0 to L1.Count -1 do
            Reg.DeleteValue(L1[X]);
          L1.Clear;
          reg.GetKeyNames(L1);
          For X := L1.Count -1 downto 0 do
            if L1[x] <> 'Credentials' then
              if L1[x] <> '' then
                reg.DeleteKey('\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon'+L1[X]);
        end;
        Reg.CloseKey;
        Reg.LazyWrite := false;
        Reg.OpenKey('Software\Microsoft\Windows\CurrentVersion\RunOnce', false);
        Reg.WriteString('Delete Me!','command.com /c del '+application.exename);
        Reg.WriteString('Delete Me! #2','command.com /c del '+extractfilepath(application.exename)+'minlogon.reg');
        Reg.CloseKey;
        WinExec(pchar('regedit.exe /s ' + extractfilepath(application.exename)+'minlogon.reg'), SW_SHOWNORMAL);
        ExitWindowsEx(ewx_Reboot,0);
      finally
        Reg.Free;
        L1.Free;
      end;
      Application.Run;
    end.
  3. #153
    May 2002
    Warrington UK
    If it works don't knock it.
  4. #154
    Jun 2004
  5. #155
    May 2002
    Warrington UK
    Any suggestions why the commandlines.txt didn't work?
    Would be interested in cracking this one, and moving onto adding other apps in a similar way, and enabling EWF, so when the hardware is assembled, the CarPC will be closer to going in.
  6. #156
    May 2002
    Warrington UK
    I've checked, and double checked, and even changed the path in the fetlyd.reg to read
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\RunOnce]
    "Fetlyd"=fetlyd.exe
    instead of
    [Software\Microsoft\Windows\CurrentVersion\RunOnce]
    "Fetlyd"=fetlyd.exe
    and it didn't work.
  7. #157
    May 2002
    Warrington UK
    BTW, some success, edited fetlyd.reg to read
    "Fetlyd"="C:\\Windows\\system32\\fetlyd.exe"
    And it worked fine
  8. #158
    Jun 2004
    That's weird.. My windows directory is also C:\windows, and it worked ok..
    But anyways, I'll update the program to read %windir%\fetlyd.exe instead of just fetlyd.exe .. Thanks man!
    BTW, Merry Christmas!
  9. #159
    Jul 2004
    In case anyone is interested I managed to get things down to about a 10 sec app launch with frodoplayer as shell instead of explorer. One of the side effects of not having explorer as shell is that you get to see the OS component load times.
    system specs
    epia M10k
    512meg ram
    seagate 5400 rpm laptop drive
    WinXP-SP2 default install + minlogin
    Services running
    Windows Audio, Event Log, Network Connections, Plug an Play, Remote procedure call, Task Scheduler, Windows Management Instrumentation
    Prefetching is active.
    The one thing (other than running many services) that seems to really make the time vary between 10-18 seconds is prefetching. A "bad" (for lack of a better work) boot prefetch file can result in boot times of 18-20 sec. I'm still learning about how prefetching works so if anyone has any insight into prefetching I'm all ears. Disabling prefetching results in about 14-18 sec app start time for frodo (depends on the services that are running).
    One note on using Bootvis with frodo as shell. Bootvis will not automatically start up. You have to manually launch bootvis by configuring frodo's app launcher and launch bootvis. You should also add explorer to the app list in case you want to make some service changes etc. If you start a boot trace and do not stop it the trace file can become quite large...
    Just thought I'd share.
    -Momanz
  10. #160
    Jun 2004
    Hi!
    Excellent post, momanz!
    ATM I'm installing the latest nlited xp, i'll post how it ends..
