Page 17 of 27 FirstFirst ... 7891011121314151617181920212223242526 ... LastLast
Results 161 to 170 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #161
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    All I have to do is now is work out why I get an error one with EWF.
    4x4 in a turbo stylee.
  2. #162
    Jun 2004
    Doublecheck all the registry entries.. maybe you forgot one?
  3. #163
    May 2002
    Warrington UK
    Quote Originally Posted by FetLyd
    I copy and pasted the ones listed on the thread about ewf, but I will double check. Cheers.
  4. #164
    Jun 2004
    Did you remember this one?
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf]
    "ErrorControl"=dword:00000001
    "Group"="System Bus Extender"
    "Start"=dword:00000000
    "Type"=dword:00000001
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
    "UpperFilters"="Ewf"
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0]
    "VolumeID"="{1EA414D1-6760-4625-8CBE-4F9F85A48E15}"
    "ArcName"="multi(0)disk(0)rdisk(0)partition(1)"
  5. #165
    May 2002
    Warrington UK
    Code:
    Will need to double check that when I get home from work, cheers.
  6. #166
    Newbie SlashEMc2k's Avatar
    Dec 2004
    UK
    Make sure you have the right ewf.sys its in the right directory system32/drivers
    and you have the correct ewf manager in system32 dir.
    I kept getting the error1 it was because I was using ewf FROM XPE SP1 and not SP2
  7. #167
    May 2002
    Warrington UK
    Quote Originally Posted by SlashEMc2k
    Yep
    yep
    I used the ones from the EWF.zip, EWF and minlogin archive that was posted to the thread.
  8. #168
    Dec 2004
    UK
    So you downloaded and used this file:
    http://test.crimsonstain.net/EWF.zip
    Did you read this forum aswell to see the problems I had?
    New EWF + MinLogon and CF instructions
  9. #169
    May 2002
    Warrington UK
    Yesm think that was the ones I used.
    Ah no, didn't see those. Wil read that thread.
  10. #170
    Low Bitrate QuickCarl's Avatar
    Jun 2003
    Atlanta
    Eureka!
    Witched to safe mode and the winlogon.exe rename and minlongon.exe rename problem was overcome. Followed the rest of the directions. Piece of cake.
