Page 2 of 27 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #11
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    What is EWF, do we have to run it?
    CarPC status: iPod, 3,456,217 songs so **** you
  2. #12
    FLAC SFiorito's Avatar
    May 2004
    Motoko: go here for EWF Using EWF on regular WinXP
  3. #13
    Oh kool thanks, guess i'll skip that part of this config
  4. #14
    Why is winlogon reproducing is self! aahhh u cant get rid of it!
    edit:: done it, using quick hand skills
  5. #15
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Anyway I could get this for my Windows 2003 install? Would it work by any slim chance?
    CarPC install is starting to come along again...
  6. #16
    May 2004
    I don't see why not. You may want to try it in VMWare or VirtualPC first though.
  7. #17
    May 2004
    Okay, so who's tried this and have they checked things out? My VIA system seems fine. One thing I noticed reading through some documents on MSDN is that MSFT claims hibernation doesn't work with minlogon because of some security issues. But I've got hibernation working on my VIA system with minlogon and ewf fine. Standby works as well. But maybe that's because I had hibernation set up before I installed minlogon.
    **EDIT**: okay, it seems in SP2 minlogon DOES support standby and hibernation. So ignore my last...
  8. #18
    May 2004
    This mod would only improve cold boot times and would not affect resume from hibernation times correct? But I guess if the memory footprint is smaller with minlogon, then coming out of hibernation could be a little faster too.
  9. #19
    Ive ran into trouble, i followed the instructions, system boots up comes o the logon screen with Administrator as the only user to select, i click on it it says "logging on" (underneath) then changes to "Saving Settings" and dosnt logon and stays in the logon screen
  10. #20
    May 2004
    Motoko: If you're getting the logon screen then you missed something. You said you were having problems copying minlogon so I'm willing to bet your system is still running winlogon. When the windows file protection dialog comes up you need to hit cancel overwise it'll restore the normal winlogon.
    CombatCQB: that's correct. hibernation won't benefit from this unless you consider a smaller OS image as well as less ram being used up. This mod is purely for cold booting speed and footprint.
