Page 22 of 27 FirstFirst ... 12131415161718192021222324252627 LastLast
Results 211 to 220 of 269
Thread: Using minLogon to speed up booting and decrease footprint
  1. #211
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I use the 7.2k Hitachi 2.5" ... runs cool, quiet, and fast.
  2. #212
    Jul 2004
    Hmmm... My EpiaM10KN with a 2.5" seagate drive (5400rpm) usually boots in 13-15 seconds with minlogon installed. Disable networking and most of my services and I can get down to 10-12 seconds.
    Use frodo as shell and I can have the app launch in about 10 seconds (useable in about 13-14 seconds) Take a look at the bootvis plots in the link below.
    My guess is that your configuration could use some optimization. What do your driver delays look like when you run bootvis?
    -momanz
  3. #213
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    I'm not really an expert at reading this chart but as far as I can tell, not good. Just like you said.. networking. But I use 802.11B how can I disable networking?
    http://brooklynzoo.org/img/Baileybootvis.jpg
  4. #214
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Bailey
    Look in the services page in the control panel under administrative tools.
  5. #215
    Jul 2004
    Actually your times don't look bad ~ 16 seconds. The brown bar on the graphs represents the point in time where the "start" button in explorer becomes available, at that point in time you can start using the os. The spoolsv.exe is your print spooler, go head and disable that service. S3hotkey and Vttimer are installed by the graphics driver install program. I've removed them from the startup on my system (delete the relavant registry entry) and have not noticed any ill affects.
    Are you including the bios time (time when the system startup screen showing bios version, cpu, memory, connected devices etc to XP start) in the times you listed in your previous post? If so you can reduce that to about 5-6 seconds by enabling the fast boot option and disabling devices that you are not using (onboard lan, FIR etc).
    As for the long network delay... the problem may be in either the configuration or the drivers. Try a couple of different driver versions and see if that makes a difference. With my dlink usb stick the older drivers can lead to a 6-7 sec delay, while the latest version (surprisingly only found on the microsoft site) has about a 1-2 sec delay.
    -momanz
  6. #216
    Nov 2004
    NYC
    By combing through the CMOS settings, and disabling two or three more services, I was able to shave off another 2 seconds to the start button. As for the "network delay," that's caused by winxp taking it's time to start up my wireless connection. I have no idea why. It doesn't mess with the boot time at all, just the time to get a connection. In fact I took out the wifi card and it only had like a 1/2 second off and that was probably from pcmcia.sys. It doesn't bother me much.
    Anyway, momanz, thanks for all your help and advice. I think I've reached the comfortable limit on a 4200rpm hard drive -- about 15 seconds flat -- I know I could go around disabling all kinds of services but I feel that would lead to trouble down the line and it's not worth a second or two. The only option now is to move to 5400rpm or 7200rpm.
  7. #217
    Jul 2004
    Glad to help.
  8. #218
    Apr 2005
    Minlogon and Reatogo (BartPE), is it possible?
    Hi all,
    i know hoe to use Minlogon in "regular" WinXP, it works me well, thanks to SFiorito :-)
    I use ReatogoXPE (www.reatogo.de), based on BartPE (www.nu2.nu/pebuilder). It would be great if we can integrate minlogon under Reatogo.
    If i use SFiorito guide in Reatogo, it reboots when desktop is activated. Can anybody help me, please?
    Pavel
  9. #219
    Dec 2005
    minlogon
    1) can anyone hook me up with minlogon.exe, i know its a part of XPE buti don know wher to get it?
    2) i have my nlited xp installed with the nothing on but Event log like one the thread on this forum but my installed XP still about over 500MB, can anyone tell me why?
    Apr 2005
    Hi,
    Have you got a Embedded Studio installed? If yes, search a repository for minlogon.exe (17 kB).
    Pavel
