Page 4 of 27 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #31
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by SWC
    So is there a way to force quit apps with minlogin?
    Have a program that uses systemhook to alt+ctrl+del that brings up a task manager. Search for alternative task managers.. they should work.
  2. #32
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Well i got my system back to using explorer for the shell.
    I still had network access to the drive, so i copied explorer.exe to the centrafuse folder and renamed the files then rebooted. It worked like a charm.
    also did a little research and i can't find anyway of enabling CTRL+ALT+DEL with minlogon.
    We are, will have and forever will be...
    But not tommorrow!
  3. #33
    FLAC SFiorito's Avatar
    May 2004
    What errors were you getting when you changed the shell??
    *EDIT*: Also, what registry key did you change for the shell. I seem to remember that minlogon handled things differently maybe... Not sure about that one, I'll have to reread the MSDN docs.
  4. #34
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by SFiorito
    I am interested as well. Maybe they can be corrected easily.
  5. #35
    Jul 2003
    I just changed the 'Shell' entry under [HKLM\SOFTWARE\MICROSOFT\WINDOWS NT\WINLOGON]
    from 'Explorer.exe' to 'C:\Program Files\...\centrafuse.exe'
    Yeah, i didn't write down the errors, which was stupid. I will change the shell again and take down the errors and pass them to the creator of centrafuse.
    But not tommorrow!
  6. #36
    Jun 2004
    One thing that's a bit unclear for me.. Is this method using XP emb. or an ordinary XP? (Nlited).. If it's NOT XP emb., where can we download minLogon?
    EDIT: Nevermind.. I found it.. Thanks SWC!
  7. #37
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    You'll get an error, everything but one subkey will have been deleted. Then highlight all the reg values in Winlogon and delete them.
    What reg files do you delete? i dont see any
    CarPC status: iPod, 3,456,217 songs so **** you
  8. #38
    May 2004
    If you don't see any reg values or keys under winlogon then you're fine. Now run the reg import file.
  9. #39
    Jun 2004
    Hello!
    ATM I'm burning an Nlited XP with minLogon and EWF.. I'll tell you guys how it goes, and if it's good, I'll write up a short guide..
  10. #40
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Has anybody tried Talisman windows skinning software, that has an automated shell switcher...
    Looks quite neat too.
    John
