Page 6 of 27 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #51
    Nov 2004
    1Gig CF CARD (414MB used)
    Windows XP Pro SP1
    Nlite ISO install
    minLogon
    EWF
    BOOT TIME: 10SEC!
    will boot vis cut that down?
  2. #52
    Constant Bitrate OdysseyPC's Avatar
    Oct 2003
    ACT, Australia
    Quote Originally Posted by arise360
    Doubt it, it's only for profiling boot times.
    Caputer Mk. II
    '02 VX Holden Commodore Series II Executive
    MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
    Morex 60W DC-DC, Custom S/SDC
    OS/Software: Developing...
  3. #53
    Nov 2004
    Quote Originally Posted by OdysseyPC
    thats what I thought.
    any other Ideas on how to speed it up?
  4. #54
    Jan 2003
    Ruston, LA
    Don't listen to Microsoft's bull****. Bootvis DOES reduce boot times.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #55
    Constant Bitrate Maukio's Avatar
    Jul 2004
    Oklahoma
    Hmmm, I'm having problems similar to the earlier dude. I followed the instructions exactly. I ran into a problem with Windows File Protection. I didn't get any kind of message or pop-up that alerted me about Windows File Protection (no window to hit cancel on). But I noticed that when I came back to the System32 directory, after going to where I had minlogin stored to copy it, winlogon.exe, which had been deleted, was back. I found a place online that showed me how to disable Windows File Protection, I tested it out and it worked. Then I continued with the minlogon instructions. I checked to make sure and it was 17KBs. I imported the registry key after deleting everything. Once I finished all that I rebooted and the classic login screen popped up. I tried logging in with my user name (no password) and it the screen would go away and just have a blue background, it would wait a few seconds, then the login screen would pop back up. After that I tried using my Administrator account and password, this produced a bit different results. The login screen disappeared, I got the blue background again, but this time the Windows login sound played (which I previously had disabled), but about 2 seconds after it finished, the shutdown song played and the login screen popped backup. Anybody have any ideas?
    '99 Accord LX
    Pics of CarPC Setup
  6. #56
    Maximum Bitrate knubile's Avatar
    Windows XP Pro SP1
    Nlite ISO install
    minLogon
    EWF
    BOOT TIME: 10SEC!
    Any idea what that boot time is on a regular drive? I have the same setup on a laptop drive booting in 35 seconds.
  7. #57
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Windows XP Pro SP1
    Nlite ISO install
    minLogon
    EWF
    BOOT TIME: 10SEC!
    Post your boot vis, log file. What speed is your computer ? (Ram, ram clock speed, cpu cpu bus ? )
    Bootvis is from microsoft and says it can increase boot times by 2-3 seconds... it does this by optomizeing the drive... which you can do manually..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  8. #58
    Jan 2003
    Ruston, LA
    I have the CTRL-ALT-DEL problem solved.
    Gimme a minute.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #59
    Jan 2003
    Ruston, LA
    Quote Originally Posted by frodobaggins
    Gimme a minute.
    Ok I got it all working nicely. I'm too tired to pack it all up
    and release tonight, but as soon as I have time tomorrow I'll
    post up the solution and instructions.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #60
    Jun 2004
    Quote Originally Posted by egeekial
    So how can we slipstream all this into a fresh install? Is it possible with nLite?
    Should be possible.. I tried replacing winlogon.ex_ in the i386 folder, before building the iso.. everything installed ok, but left me with an BSOD at the first boot.. Guess XP needs some stuff in orig. winlogon at the first boot, but I'll have to give it a few more tries.. I'll keep you updated!
