Page 8 of 27 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 265
Thread: Using minLogon to speed up booting and decrease footprint
  1. #71
    FLAC SFiorito's Avatar
    May 2004
    Regardig bootvis: doesn't that just layout boot files on the hard drive to minimize seek time? I've run it a few times, but saw no difference at all on the CF card. I wouldn't expect to since the CF card has such small seek times. You guys all disabled the auto chkdsk, too right? That was eating up at least a second on my system.
  2. #72
    Jan 2003
    Ruston, LA
    Quote Originally Posted by AlienEclipse
    also did a little research and i can't find anyway of enabling CTRL+ALT+DEL with minlogon.
    Solution:
    FIX: CTRL ALT DEL with "MinLogon"
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #73
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I didn't get a WFP pop-up or anything. Presumably my nLite install killed WFP. I just tried to do the minLogon again on a stock SP2 install (i.e. no nLite) and did run into the WFP problem. It never warned me -- just silently replaced the new file with the standard winlogon.
  4. #74
    May 2004
    Hmmm... I wonder if it matters that (on the stock SP2 systems) I've always done it logged in as Administrator??
    *EDIT*: I double-checked, and I have WFP enabled, so I don't know what it could be.
  5. #75
    Maximum Bitrate knubile's Avatar
    hmm. I just ran into the problem with my last attempt. nLite. Checked the disable protection checkbox that worked for me before.
    This time it didn't work. I wonder if its something else. I wonder if there's a component that nLite removes that results in the file protection not working.
  6. #76
    Constant Bitrate Maukio's Avatar
    Jul 2004
    Oklahoma
    Yeah, there's gotta be some other variable in here. WFP was turned off and I made sure it was the XPe 17Kb file and I followed the registry instructions very carefully. I wonder what else it could be? Maybe some services you all have disabled or enabled that I don't? Hardware? I really have no clue, just throwing out suggestions.
    '99 Accord LX
    Pics of CarPC Setup
  7. #77
    Jun 2004
    Quote Originally Posted by SFiorito
    Good job FetLyd, that's a great tip! As far as those of you having problems with WFP and copying minlogon: I don't know what to tell you. Every machine I've tried (including a default SP2 install) I got a warning dialog from WFP which I was able to cancel. It looks like most other people got the same thing as well. The problem is that the file and registry entries go hand-in-hand, so if one is screwed up the whole logon process gets screwed up!
    Thanks alot man! I'll see if i have the time to put together a small program today, that'll copy the files over AFTER installation.. Should be able to get around that stupid BSOD then...
    EDIT: BTW, I didn't delete any reg. entries before running the winlogon.reg file.. Still, it works fine..
  8. #78
    Constant Bitrate HoSS's Avatar
    Dec 2004
    Just copy it over in recovery console mode (boot from Win CD), and leave file protection on, its easy!
    HoSS
  9. #79
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    What if you dont have a cd drive?
    CarPC status: iPod, 3,456,217 songs so **** you
  10. #80
    I get a write access denied error when I try to delete winlogon.exe. It says another program is using etc..
    Is that what WFP does? Or is this something else?
