Originally Posted by
knubile
I have a similar setup as your nobia. From what I understand Fat32 will reduce the number of writes to the drive and therefore will also reduce ram used by EWF.
I had my fresh install around 380mb. I installed all codecs, .net, wmp10 and drivers on the OS partition. Make sure you turn of paging. I do not have hiberate enabed, so that saves me 512 megs right there.
Is hibernation really a must? Using minlogon my boot up is only about 5-10 seconds slower than coming out of hibernation with 512 megs of ram. 512 is a must to run all my apps without a pagefile.
So hibernation adds 512 megs to the install and buys you between 5-10 seconds on boot up. I didn't think it was worth while.
