1 Attachment(s)
FIX: CTRL ALT DEL with "MinLogon"
Here is the fix for those using minlogon and would like to have
Ctrl Alt Del working again.
Code:
©2004 FrodoPlayer.com
©2004 Kevin Lincecum
CAD_Trap Service
Purpose: To detect CTRL ALT DEL and launch the task manager.
Used for systems using "minlogon" which do not catch this message.
Installation:
Put the files where you want them installed.
Run install.bat
Reboot
To remove, first stop the service.
Then run uninstall.bat
Reboot, then remove the files.
Note: If you want the service to restart if killed, you
must set this manually in the service manager of windows.
Changing the Path to Task Manager (or use an alternate)
Edit CAD_Trap.ini
Put in the appropriate values.
Enjoy.
Frodo
