Page 11 of 32 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #101
    Sep 2003
    LA, CA
    i tried to hibernate after ewf enabled...
    i found interesting thing...
    i works but after i shut down normally...
    it boots up normal...
    so i think it still writes states when shutting down...
    but ewf looks working nothing else changed...
    what did i do wrong or miss?
  2. #102
    FLAC SFiorito's Avatar
    May 2004
    you created the resmany.dat file on your C drive with ewf disabled, re-enabled ewf, and rebooted? you have the ewf version of ntldr installed? when you run ewfmgr it gives you a good status?
  3. #103
    Sep 2003
    LA, CA
    Quote Originally Posted by SFiorito
    yes
    yes
    yes
    somehow i hibernate twice in a row then now it seems like doing HORM
    but after couple of boots from HORM i get blank screen then no response...
  4. #104
    May 2004
    will the ewf method work on windows 2003 with minilogon?
  5. #105
    May 2004
    it might...haven't tried it myself though.
  6. #106
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    Read only
    I am installing minlogon, and whenever i rename the original winlogon file it automatically creates a new one. I have changed windows/system32 froma read only folder. When ever i change it, it automatically revert, this is so friustrating, I have tried changing the attributes using a command line prompt, and can't do it that way either
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  7. #107
    Feb 2005
    S Ohio
    if i replace winlogon before it regenerate, it automatically changes the file.
    Here is what im saying... minlogon is 17k, and winlogon is 491k
    I make a rename winlogon.exe to winlogon_bak.exe or winlogon.exe.bak
    then i paste minlogon in windows\system32
    By the time i do this, a new winlogon.exe appears, and the backup one is still there as well
    So Before i move minlogon, i rename it to winlogon (17kb) , then i click copy
    I go to windows\system32, delete winlogon.exe (491kb) then quikly click paste, and winlogon (17kB) appears, then 10 seconds later winlogon become 491Kb.
    The folder is not checked as read only now
    wtf?!?!?
    My NEW carPC
  8. #108
    May 2004
    that's Windows File Protection. you need to disable it or replace winlogon in the dllcache folder I think? can't remember right now... if you use nLite you can disable Windows File Protection. either that or use a registry hack, search for SFCDisable
  9. #109
    Aug 2005
    I downloaded the eXP trial and noticed that there are 2 minlogon files. One is 15k and the other is 13k I'm currently using the 15k logon file, but crtl-alt-delete doesn't work any suggestions? Using the current minlogon I can't use windows update. I can launch it, select files, and even download them, but installation fails.
  10. #110
    May 2004
    for CTRL-ALT-DEL look at the sticky thread right above this thread...
    for Windows Update I recommend switching back to Winlogon, reboot, upgrade, switch back to minlogon, reboot.
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
