New question for you. My system keeps coming up saying that windows didn't shut down properly. Is there any way to get rid of this?
Hello were can a find this ntldr i surch in the pc and nothing were is he hiden?????"1-Rename the ntldr file on your root drive to ntldr.bak"
did you read all of the instructions???it's probably the bootstat.dat file in your windows dir.
Oops...sorry, I read the instructions a couple of times about a month ago...so I THOUGHT I knew it all and skimmed it when I actually did it!
did everything as this says http://mason.gmu.edu/~sfiorito/eXPinstall.htm
As soon as I reboot I always get a blue screen ;(
A ******* Problem has beed detacted ;(
has anyone a clue ?
Me too. are you using Nlite?
for me it seem that Nlite do this. I'm not sure wye yet. but I'm trying diff setting in Nlite this time :P
I will let you know if anything good happens.
Carputer Status: 99% :(
Car: 2005 Mazda 6
Motherboard: VIA Epia M10000
Display: Holy Grale
Power Supply: High Green Powersupply
GPS: Hicom 204 GPS USB Mouse
Software: Windows FLP, CentraFuse, on Compact Flash
Having lots of problems booting from CF card.
These are the steps Ive taken:
Installed tinyxp rev2, followed SFioritos` instructions.
The computer boots up Super fast and xp is under 500mb great.
I format the CF card "c: /s" reboot and remove floppy.
CF boots up into dos.
I do another "format c:"
Get another computer connect hardrive with TINY XP and CF card
boot into standard XP which I use to do "xxcopy" http://xxcopy.com
I "xxcopy d:/ e:/ \CLONE" TINY XP to CF card no errors all system file everything duplicates onto the CF card.
I turn the computer off put the CF card onto another computer to test if it boots into xp but nothing happens. the IDE-CF card is detected from bios it just doesn`t boot into xp?
I`m using an xtreme III CF card
anyone got any ideas what I could be doing wrong?
Should I be formatting the CF card as fat32?
Or just leave it as fat from the format in dos?
I tried the whole thing again from scratch and I am now getting non-system disk or disk error on boot.
If I boot into dos from floppy I can still explore the structure of the CF card and looks as if it should all work. Could this possibly be a problem with my BIOS?
I might be in the wrong thread, but i really need help. i had via MII 10000, and xpe start up and working flawless, but i cant never get the onboard sound card to work. if anyone can help please do, becuase im really tired of what im doing.
BL
I'm Having the same problem with my p4 board, for some reason windows does not see the audio drivers or somthing of the sort, im getting the " waveOut error" " there is no driver installed on your system" i tried folling some ideas online like upgrading directx and uninstalling and reinstalling, nothing seems to work so far. has anyone else had this problem?
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
