Page 15 of 32 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #141
    Dec 2005
    Quote Originally Posted by bobs987 View Post
    I'm Having the same problem with my p4 board, for some reason windows does not see the audio drivers or somthing of the sort, im getting the " waveOut error" " there is no driver installed on your system" i tried folling some ideas online like upgrading directx and uninstalling and reinstalling, nothing seems to work so far. has anyone else had this problem?
    i fixed my problem already!
    what os did you use?you used xp embeddedi used xpe not tinyxp or anything like that. xp you can control what component you need to include and what not! so try xpe, it much better. i have my ran on cf. if you just need to run the OS and and RR, it can be done under 200mb, but you keep adding stuff like me, you will end up with about 700mb. if any one know how to install .msi without having .net2.0 on xp embedded, please show me ! if you used xpe and still having a problem let me know what i can help!
  2. #142
    Dec 2004
    CT
    Quote Originally Posted by IntellaWorks View Post
    Have you tried installing or slipstreaming the correct audio driver for your systemboards???
    Yeah, that was the first thing i did, it seems to e something with the tiny xp version and my motherboard. when i install the drives it only installs the audio driver and nothing else like game controller and microphone etc. I might have to go the nlight way but dont have the time right now, if you guys can think of anything else that would be great, sorry for lack of info im at work and i shut down my home computer by accident. Just wondering if any one had this problem with tiny xp b4
  3. #143
    FLAC sama's Avatar
    Feb 2006
    London, UK
    did you disable any services? try enabling all services and installing. check that the windows audio service is started.
    I'm having a lot of troubles installing the belkin bluetooth drivers. it gets to the end and keeps complaining about some error code. when I look it up, it's to do with access to directories. I use minlogon, and I think that's the cause of most problems since windows cannot logon as a different user, and all sorts of issues like that. As you can tell by the way I'm talking, I'm not 100% sure what's going on, these are all the fragments in my head that haven't yet fallen into place!
    if anyone can show me the beacon of light, please do! if not, then search around in those areas, I think the solution is there.
  4. #144
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Try using rev 5 of tinyxp. I know its disable the pcmcia driver though so backup that driver if u do use tinyxp
  5. #145
    Sep 2006
    Thank you SFiorito, great work!
    Just one problem... Hibernation is not working without xpepm. When I try to hibernate with the windows command (on the shutdown options). Any ideas?
  6. #146
    Sep 2006
    Problem solved. I just shutdown and came back on hibernation data.
    Thanks!
  7. #147
    Oct 2006
    I've a problem too.
    Here's what I've done:
    Primary Master: HDD - winXP
    Secondary Master: CF-Card [NTFS]
    Install winXP on a HDD [Primary Master], then install EWF [works properly for the partitions C: (HDD) and D: (CF)], then I used XPLite and created my own WinXP
    I don't have a chance to install another drive to this computer, so i take the HDD and the CF and put it in another System. Now I copied all files from the HDD to the CF. I reput the CF to the Computer where it has to work. It boots up to the blue Screen where first stand "Microsoft Windows XP" - this is after Windows XP is loading and before the "Welcome" Screen appears. [CF is still at Secondary Master]
    So I put the HDD to the Computer again and add the line multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn in boot.ini. If I start the Computer then and choose the second Windows XP Prof. it works fine, just a lil bit slower than from HDD.
    I have no CF-to-IDE Adapter there's already one on the board.
    How can I get it working fine without having the HDD connected to the system?
    Sorry for my english
    Edit: Some Updates - I didn't install minlogon at the first time. I tried it now at the HDD (everything works) and on the CF. If I boot now from the CF (with connected HDD or without, it's the same problem) I get a blue screen where is said, that winlogon was closed abortive and the System will shut down.
  8. #148
    FLAC SFiorito's Avatar
    May 2004
    Can you change the boot order in your BIOS? Try disabling the primary IDE channel so that the CF becomes the primary.
  9. #149
    Oct 2006
    I tried it. It's already the same problem
    Another Update: Is it normal, that if I change the registry of partition C: (HDD) that the registry of partition D: (CF) gets also changed?
    Edit: I also tried to create an image of my WinXP end restore it at the CF-Card. There's also the same problem. When Windows freezed and I press ESC or Return there comes a sound like pressing a key at bootup.
    My CF-Card:Kingston Std 2GB
    It's workin now. I copied it with [booting with] Drive Image 2002 and didn't boot into Windows.
  10. #150
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Awesome thread so far. Very informative. I am going to attempt a solid state OS install. I was wondering if this could be done on a 1gb USB 2.0 stick? If not ill just do the CF card. My problem is that I downloaded the XPE sp2 and I cannot get it to do anything. I can't find the repository that you are talking about. I don't know if they updated it or what. After I downloaded everything all I have is 3 cd's under c:/program files/XP embedded. Is it possible for someone to email me the files necessary for ewf? I already have done the minlogon mod.
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
