Page 17 of 32 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #161
    FLAC SFiorito's Avatar
    May 2004
    did you create the resmany.dat file on the C: drive and replace the XP NTLDR with EWFNTLDR?
  2. #162
    Newbie jessebs's Avatar
    Jun 2005
    Texas
    Yes. The problem is with the actual hibernation. Clicking hibernate seems to do nothing
    [###########--] 85% complete - Software Installation
    To Do: Complete Voice Recognition, transfer hardware into car and wire.
  3. #163
    Jun 2005
    Texas
    Actually, it was a problem with minlogon. When i switched back to winlogon it works. Thats what I get for not iteratively testing.
  4. #164
    May 2004
    oh, that's probably the famous ACPI button issue....
  5. #165
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Question. How can I delete files from my non ewf drive permanantly without it coming back when i power on the computer again without disabling ewf. Any way of doing this.
  6. #166
    May 2004
    if your drive is not protected by EWF then it shouldn't be restoring files?
  7. #167
    Jun 2006
    Houston, TX
    my D drive is not protected by ewf. But when I delete an mp3 the files comes back due to the recycle bin being protected. Its the same hard drive separated partition. Hope that helps
  8. #168
    May 2004
    what happens if you empty the trash and then reboot? or are you doing that already?
  9. #169
    Jun 2006
    Houston, TX
    doing that already and it still comes back the song or any files. It doesn't happen to you?
  10. #170
    May 2004
    i'll have to double check. I always use small flash devices for my main drive so I always have a single partition.
    if you run "ewfmgr c:" and "ewfmgr d:" what's the output? I'm assuming "d" is your secondary partition.
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
