Page 18 of 32 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #171
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    i have never tried ewfmgr d: but i know i can add music to my d partition and the music stays. but I just cant delete them without disabling ewf on my c partition.
  2. #172
    Newbie aleshu's Avatar
    Oct 2006
    Buenos Aires, AR
    I have my system (EWF/HORM) working fine. I recently put it on CF and my boot times on hibernation and cold boot have increased significantly from 20 sec to 28 sec (hib) and 25 to 37 (!!!) sec on cold boot.
    Could it be that I added a not EWF'd HDD to store mp3? Not probably but who knows..
    Im using an 1Gb Ultra II and a IDE2CF adaptor.
  3. #173
    Mar 2007
    Quote Originally Posted by tn6478 View Post
    my D drive is not protected by ewf. But when I delete an mp3 the files comes back due to the recycle bin being protected. Its the same hard drive separated partition. Hope that helps
    tis is becouse it is a fixed drive, if you do scandisc it will be gone these files
    it is becouse windows knows your file structure of your d drive, and sinds it is read-only it dos not know these files are gone when you reboot. u better use a usb disk, than you won't have this problem.
    for i don't know how to fix this behavior
  4. #174
    Mar 2007
    Disable Recycle Bin
    You could try turning off the recycle bin
    Right click my the recyclebin then properties select the global tab and turn off the recycle bin for all drives.
    Cheers
  5. #175
    Newbie Machinist's Avatar
    Dec 2006
    SFiorito, Some people were having issues using the ewfmgr command to access the EWF volume.
    Failed getting protected volume configuration with error 1
    The latest XPe Repositories has 3 or 4 different versions of ewf.sys, ewfmgr, and ewfntldr from SP1 and SP2, FP2007. I'm not quite sure why these older revisions were not removed, but if someone ended up implementing using older revision they would come across the error.
  6. #176
    May 2007
    Federal Way, WA
    MinLogon... No difference?
    Hey guys,
    has anyone else experienced no change in bootup times when switched to the minlogon? I did the change per spec and it is exactly the same. If there is something I should check, please let me know. Thanks!
    -Erik-
  7. #177
    _
    Mar 2004
    Little Elm, Texas
    SFiorito - would it be OK with you if I added your tutorial to the new FAQ system. Of course, all credit given, as with other articles.
    Would this be ok with you?
    Jan Bennett
  8. #178
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Anyone make a Ghost backup of there CF drive all setup? I have a 2 gig CF and a via board that has a cf slot. It would be great if someone would make a nice backup, Maybe remove windows key to be on the up and up. Not sure what the legalities are on unkeyed windows XPE images. Just a thought. Maybe upload to torrent site.
    Specialy if someone has HORM running.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  9. #179
    Dec 2006
    I think this is not possible, as XPe builds are very specific to the hardware on the particular system it is created for, and the FBA won't work as well. Also rather than using a windows key, XPe uses a PID which must be input before the image is deployed.
  10. #180
    FLAC SFiorito's Avatar
    May 2004
    Quote Originally Posted by RedGTiVR6 View Post
    Sorry, I've been away for a few weeks....Yes, this would be fine!
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
