Page 19 of 32 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #181
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by Machinist View Post
    I think this is not possible, as XPe builds are very specific to the hardware on the particular system it is created for, and the FBA won't work as well. Also rather than using a windows key, XPe uses a PID which must be input before the image is deployed.
    My xpe image doesn't need any key to install or run.
    The build is very hardware specific though .
  2. #182
    Jul 2007
    Hy,
    I am a new one in here!
    I have read a lot about OS tweak, last weeks, and I tried to make embed XP with HORM function, everything was ok, until the finish line.
    Problem:
    When resuming from hibernating Windows says: The last attempt to restart the system from its previous location failed... And I have 2 possibilities to choose:
    Delete restoration data...
    Continue...
    How can I disable this dialogue?If I choose Continue, everything goes ok!
    I tried to search about something similar, but I didn't find anything!
    And, yes, I have deleted bootstat.dat
    please help!
    and thank's for this great forum for inspiration!
  3. #183
    Mar 2007
    Östersund, Sweden
    did you create the resmany.dat file?
  4. #184
    Jul 2007
    Yes, I created Resmany.dat!
    HORM is working, but everytime I want to resume, computer shows this dialogue! If i press continue, everything resumes ok!
    Any ideas?
    It's the last problem for my CarPc,even touchscreen is in place!
  5. #185
    Mar 2007
    Östersund, Sweden
    saw a post where resmany is replaced by horm.dat with newer xpe files
  6. #186
    Jul 2007
    The same dialogue appears!
    I don't really know do I have the latest EWF files!
    I only downloaded XPe from microsoft and searched for minlogon.exe, ewf.sys,ewfmgr.exe and ewfntldr!
    I found 3 versions for each file in some .CAB files, latest were modified in 2003, so now I am using them!
    Maybe I haven't got the latest ones? If so please could someone PM me the latest ones?!
    I will be wery gratefull!
    Or maybe some other ideas?
    EDIT: I forgot, minlogon.exe didn't supported Hibernating, so that I found in this forum!
    EDIT2: Found this URL, but with these files computer is not resuming anymore(not even once)! So please somebody PM me 100% working EWF files!
  7. #187
    Aug 2007
    I was looking for a way to optimise Windows for use on a compactflashcard and found this topic and lot's of stuff about Windows XP Embedded. I'm probably missing the point, but why install XPe to get to some of the needed files to use in XP Pro instead of just using XPe on the flash card?
  8. #188
    _
    Mar 2004
    Little Elm, Texas
    I'd imagine because XPe doesn't have many of the features that XP Pro does that many people find they need or would prefer to have.
    Jan Bennett
  9. #189
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    If I remember correctly (it's been a while) the XPe you download isn't a distribution it's OEM tools to create an embedded windows environment.
    Someone feel free to correct me if I'm wrong.
  10. #190
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by NeoMatrixJR View Post
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
