Page 21 of 32 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #201
    Newbie Guinnessdawg's Avatar
    Jul 2004
    Richmond, VA
    I followed all of the steps, checked, re-checked. When I check the status using cmd prompt...I also get "no EWF volume found". I'm attempting to set this up on my hard drive so that I can take advantage of horm only.
    Craig
    ________________________________
    Pentium III
    601mhz, 288gb RAM
    60gb hard drive @7800 RPM (upgraded from 5gb!)
    nlited Windows XP pro
    Gateway Solo 2150 laptop
    power switch extended
    8" Lilli molded in-dash
    project 75% complete
  2. #202
    Dec 2006
    The original link http://mason.gmu.edu/~sfiorito/eXPinstall.htm seems to be broken for the past few days atleast
    It would be really nice if we can have a backup link or information consolidated here itself.
  3. #203
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Hopefully SFiorito doesn't mind. But attached is a PDF version of his webpage.
    We are, will have and forever will be...
    But not tommorrow!
  4. #204
    Aug 2005
    Witney, Oxon. UK
    Is it Worth It?
    I've been thinking about changing my car PC from regular hard disk XP to a CF based system.
    This thread has been established for some time now and I'm wondering if those who have gone down this route would do the same again. Or is it a case of having come so far down the road you don't want to give up and are determined to battle on to the end.
    This is not meant as criticism, I just want to understand the situation.
    Thanks for your help.
    Graham
  5. #205
    Dec 2006
    Quote Originally Posted by AlienEclipse View Post
    Thanks AlienEclipse; Your help is much appreciated.
    Hopefully SFiorito will fix the broken link soon.
  6. #206
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Here you guys go, its an archive will all the files you will need plus SFiorito's document in html form. It has all files needed for a clean EWF install. Enjoy.
    DOWNLOAD
  7. #207
    FLAC SFiorito's Avatar
    May 2004
    hey guys, sorry my account was shutdown since I graduated last year. thanks for the PDF. I have a blog that I had planned to post updated instructions on along with more info. Lots of stuff going on for me right now, but hopefully this week I can clear my plate and get things fixed up.
  8. #208
    May 2004
    updated the link in the first post....
  9. #209
    Dec 2006
    Thanks SFiorito and blk02si
  10. #210
    Nov 2007
    The Netherlands
    EWF Tool
    This tool can do all for you EWF & HORM, you just need the files blk02si provided also.
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
