Page 28 of 32 FirstFirst ... 181920212223242526272829303132 LastLast
Results 271 to 280 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #271
    Jul 2008
    West Virginia
    Quote Originally Posted by SFiorito View Post
    where'd you buy the SanDisk from? ebay? what CF-IDE/SATA adapter are you using? I was booting up in the low 20s when I had an Extreme III so that doesn't look normal.
    It was from Ebay, but it was new in the box with the circular plastic tabs still attached. (I already got burned once buying some from Hong Kong that was fake). This time I paid more and got the legit thing from a store with 1000's of positive feedback in NJ, so I really don't think (or hope) that is the problem. Truthfully, in Windows, it is more or less fine as really it is the booting and shutting down that is the real issue. When I select "Start Windows Normally" it gets through the bar very quick but then hangs with a full bar for about a minute. Oh, and I noticed in Windows, it still detected it as being removable media under My Computer. Is that normal? I thought maybe since it was on the IDE cable that wouldn't happen.
    Thanks for the help.
  2. #272
    Jul 2008
    West Virginia
    N/a
  3. #273
    Jul 2008
    West Virginia
    After further testing, I can get it where it will reboot and run fine. I think it had something to do with EWF. I disabled it, restarted, enabled, restarted. All was fine, exept for Hibernating. Still when I try to Hibernate, it just locks up and I have to hard reboot it for it to come back on. It also doesn't seem to matter whether or not I have the resmany.dat file present with the combinations.
    Another thing I noticed that I don't know if it pertains:
    When the OS boots, I now get the black and white progress bar at the bottom of the screen. When I had this running from my HDD, I did not have any bars whatsoever (as I disabled the XP image and loading bar to help speed up things), now all of a sudden that bar is there while XP loads.
    Is there anything else special that I have to do in order to use Hibernate?
  4. #274
    FLAC SFiorito's Avatar
    May 2004
    ACPI stand by and hibernate do not work on removable drives unfortunately.
    I think there's an HOWTO on the boards for disabling XP boot status bar.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  5. #275
    Jul 2008
    West Virginia
    Not exactly sure what acpi even does, but I checked in the BIOS and the only two options were S1 state and S3 state, both of them cause the same thing.
  6. #276
    Jul 2008
    West Virginia
    Well since I have given up on the hibernate process, I now need to figure out why the computer takes so long to boot. I will be trying out to some HD speed utilities tonight to see what the speed of the drive is. In windows it runs fine, it gets bogged down from time to time, but I doubt that I should have gone from a 20 second boot on a hard drive to about a minute on the CF card.
  7. #277
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Maybe the Ghost utility changed something, You don't need any special software to copy the files from the HD to the CF. I just used a second computer running XP to hook up the image drive and the CF card, then used windows explorer to copy all the files. Worked great for me so it's something to consider. I also have an old 32mb SanDisk with DOS on it for testing things like this. If you had one of those handy you could plug it in and see if its the IDE > CF adaptor that is the bottle neck as DOS would also take a minute to boot.
  8. #278
    Jul 2008
    West Virginia
    Well I looked and I think the problem is that the CF drive is running in PIO mode, although it is set to use UDMA if available. Now I just have to figure out how to get it to use UDMA. Its only transferring at about 1.5 MB/s.
    After testing all of my CF cards, it appears that they all run in PIO mode when connected through that adapter, and they all run at a MAX of about 2MB/s. I guess I will be looking into a new CF adapter.
  9. #279
    Jul 2008
    West Virginia
    Well I just went and purchased a USB CF reader from Walmart and low and behold I now get data transfer rates of around 27 MB/s with that card. Looks like I will be ordering a new CF-IDE adapter from a legit outlet.
  10. #280
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've noticed that trying to go cheap on the card or adapter will yeild very poor results when trying to run XPE. I learned the hard way too
  1. Replies: 268
    Last Post: 05-28-2012, 10:49 AM
